News
ATI Catalyst drivers have a problem
Published on August 27, 2004
ATI has a problem in the latest Catalyst drivers. Read more
Intel To Delay P45 Chipset To Mid-June
Published on March 28, 2008
Intel is delaying the launch schedule of its P45 chipset from originally in May to mid-June, according to sources at motherboard makers. Read more
DRAM prices to see moderate increase in September
Published on September 07, 2005
Spot prices slipped in August as traders began to dump the inventory they had built since May, when DDR 256Mb DDR prices were as low as $2.3. Read more
SiS shows chipset for DDR2-667
Published on June 01, 2004
The SiS656 is the first core logic chipset which supports DDR2-667 memory. It is also the first chipset from Silicon Integrated Systems (SiS) to support PCI Express x16. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Nov '08
Published on November 10, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
  Tom's Hardware Forums » Motherboards & Memory » Aopen » AK77-600GN and GF5700LE 256MB compatibility problem?
Word :   Username :
Bottom
Author
 Thread : AK77-600GN and GF5700LE 256MB compatibility problem?
More Information
Archived from groups: alt.comp.periphs.mainboard.aopen (More info?)
Hi,
Running XFX GF5700LE AGP8x 256MB at 8x causes:
- in DirectX9.0 DXdiag missing DirectDraw B&W rectangles
and bouncing block in small window and full screen (only 1st time).
- flashing polygons / triangles in 3D games when moving.
Installed latest bios and drivers but at no avail. Slightly better with
GF5700 AGP8x 128MB but still similar 3D issues.
System:
os: WinXP Home, fully updated
m/b: AK77-600GN
bios: R1.04, Jan 20 2004 (latest)
cpu: AMD Athlon XP 3000+ boxed
ram: 512MB / 400MHz
vga: XFX GF5700LE AGP8x 256MB
hd: WD2000 8MB 7200rpm IDE
psu: HEC 350W
Is this a compatibility issue: AK77-600GN/VIA chipset versus GF5700
or a current problem ???
Any suggestions ???
John7
Related Product
More Information
"John7" <NoSp@mm.com> wrote in message news:<cc6tuk$10b$1@news5.tilbu1.nb.home.nl>...
> Hi,
> System:
> m/b: AK77-600GN
> ram: 512MB / 400MHz
> psu: HEC 350W
> Any suggestions ???
> John7
As your probably aware did you install DirectX 9.0b, that is the
newest version of DirectX. You did not mention if you did a clean
install of Windows when you changed motherboards. If you did not do a
clean install you might want to backup your system and install from
scratch. Some people have problems switching graphic cards under the
same install.
For instance if a person has an ATI card, then switches to Nvidia it
could cause some problems. Did you reduce the speed of the card from
8X to 4X sometimes this fixes the problem. Some games like the 4X
settings, even though it is an 8X card. Are your Via 4 in 1 drivers
up to date, also if your card uses a molex extra power connector are
you using it.
Does this behavior happen in an OpenGL game, as this would narrow it
down to DirectX, or give you an idea if it really is a graphics card
problem.
Rthoreau
Profile: stranger
More Information
>>Hi,
>>System:
>>m/b: AK77-600GN
>>ram: 512MB / 400MHz
>>psu: HEC 350W
>>Any suggestions ???
>>John7
> same install.
> you using it.
> problem.
> Rthoreau
To add to this; before installing any new piece of hardware be sure to
delete the old drivers first. So when installing a new VIA type mobo be
sure delete the old VIA drivers first. When installing a new vid card
do the same, but first put the desktop display in standard VGA mode, 16
colors, 640x480... That way windows will load a generic display driver
upon startup at which point you can install the most recent video card
drivers and set up your desktop to your specs.
It might also be wise to go into windows SAFE mode and right click "My
Computer" (on the desktop), left click Properties, left click Device
Manager and go to work and delete all entries, (if installing a new
mobo).. That way you satrt off with a clean slate (upon reboot) and you
can then load the device drivers you want.
Google Ads
