Archived from groups: microsoft.public.windowsxp.hardware (More info?)
About every second or third time I start my computer in the morning I get an
error message during boot up. The message reads: Hardware Monitor found an
Error. Enter Power Setup menu for details. When I enter the Bios setup and
look at the Power Tab, I don't see anything set wrong. I exit out of the
Bios setup and continue with the bootup process and the computer usually
starts Windows. Can someone tell me if I need to change anything in my
current Power settings. Thanks, Mac PS: Sorry for the long post.
BIOS - POWER TAB
Power Management Max Savings
Video OFF Option Suspend - > Off
Video OFF Method DMS Off
HDD Power Down Disabled
ACPI Suspend to RAM Disabled
Suspend Mode 1 ~ 2 Min (*This is
ghosted out)
PWR Button < 4 Sec Soft Off
SUB-MENU FOR POWER UP CONTROL
AC Power Loss Restart Previous State
Wake/Power Up on EXT. Modem Disabled
Power Up on PCI Card Disabled
Wake On Lan Disabled
Power On By PS/2 Keyboard Disabled
Automatic Power Up Disabled
SUB MENU FOR HARDWARE MONITOR
Q-Fan Function Disabled
MB Temp 25 C / 77 F
CPU Temp 33 C / 91 F
Power Temp N/A (*This is ghosted
out)
CPU Fan Speed 2445 RPM
Chasses Fan Speed 2228 RPM
Power Fan Speed Disabled (*See note #1)
VCore Voltage 1.52v
3.3v Voltage 3.26.v
..5v Voltage 4.99v
12v Voltage 11.8v
*Note #1: The Power Fan Speed has always started out slow (in the red) and
would take about a minute to get up into the "normal" RPM range. Once it
warmed up it would stay in the normal RPM range until I turned the computer
off. I "Disabled" this monitor thinking that this was what was causing the
bootup error message but Disabling this monitor did not help the problem.
The Power Temp monitor has always been Ghosted Out. Doesn't matter if Power
Fan Speed monitor is on or disabled.
Sponsored Links
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Help With Start Up Error
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
