Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
There is considerable discussion of this "problem" on some thread at
www.nforcershq.com in the drivers forum.
I recall someone discovering that a particular setting in the Nvidia
soundstorm control panel will cause rear speakers to stop working with
winamp. I don't use winamp and thus do not recall the specific
setting of interest. Read up there and you may find your answer.
Best regards,
Kyle
"Seaking" <Seaking@-NOSPAM-eastlink.ca> wrote in message
news:citv6012tc4orqo511f004gs0qae5g5g36@4ax.com...
| Somewhere there is a break down as the nVidia site drivers wouldn't
| work on my system properly.. I don't know why. I tried the nVidia
| drivers again after reading this and I couldn't get WinAmp or games
to
| play the rear speakers on the 5.1 system.. frustrating.. I must be
| missing something 'painfully obvious'..
| However, now the sound coming through from all progs, sources etc
are
| 'crackly' like listening to a not tooo perfect vinyl LP on cheap
| speakers..
| Any ways to clean this up? My original install had perfect crisp
clear
| super sounds.. I can't see to get that back..
| Thanks for your input..
| On Sun, 4 Apr 2004 12:00:20 +0100, "Noomie" <noomie@creb.ca> wrote:
| >"Latest drivers" on Asus site are not latest at all.
| >Nvidia site has latest.
| >news:560v60pi46uptvitonbkbfvdc4g6f8splj@4ax.com...
| >> On Sun, 04 Apr 2004 02:42:04 GMT, "KCB"
| >> >news:2gru60dhesh06ji6r2ip766ir23n1ednj0@4ax.com...
| >> >> Anyone up to speed on the audio side of this Mobo?
| >> >> My HDD recently died the big death of HDD and I had to rebuild
the
| >> >> system.. installed drivers and OS..
| >> >> I have CreativeLabs 5.1 speakers on the system but can't seem
to get
| >> >> all progs to work all speakers.. frustrating.. dunno what I am
doing
| >> >> wrong..
| >> >> Anyone available to answer some questions?
| >> >> Cheers
| >> >If you have the right drivers loaded and follow the manual, the
speaker
| >> >hook-up is fairly straight forward. If, on the other hand, you
have the
| >> >speakers working already and you are saying that certain
programs will
| >not
| >> >output to all speakers, that is normally not a problem - not
all
| >programs
| >> >output surround signals.
| >> Thanks for your quick reply.. I did some more looking on line
about
| >> what was happening and it's all about the drivers.. I went to the
| >> nVidia site and originaly grabbed their all in 1 drivers but this
| >> apparently caused some probs.. I just installed the latest
drivers
| >> from the ASUS site and now everything seems to work properly.. I
use
| >> WinAmp5 to DL stream tunes whilst I am working online and now I
am
| >> hearing the sound in all speakers (5.1) whereas before on the
nVidia
| >> drivers the music would only play out on the front speakers...
| >> strange..
| >> Oh well, at least I am closer to finishing the build up..
| >> Thanks again
