Tom's Hardware > Forum > Computer Peripherals > CRT Monitors > Need Help on Choosing Monitor
Forum Computer Peripherals : CRT Monitors - Need Help on Choosing Monitor
want to get a good 19" Flat Screen Monitor:
I have narrowed it down to two:
Hitachi CM721
Samsung - 955Df
Both come out to $300 after S+H
I need some help choosing + reccommend any other monitors
Also tell flaws of current two monitors selected
THANKS
Sponsored Links
I have been checking monitors on the web and chat rooms over past few days. Of the two you listed the Samsung seems to be best. If you can afford the extra money the Flatron 915FT+ beats everything else I have looked at. I just put in my order. A good listing of USA vendors for the Flatron can be found at <A HREF="http://www.lgeus.com/Product/Monitor/buy_main.asp" target="_new">http://www.lgeus.com/Product/Monitor/buy_main.asp</A>
Reply to Anonymous
- 0 +
i got mine at <A HREF="http://www.pcnation" target="_new">http://www.pcnation</A> for $364.32 includes S&H
I try to smile everyday but I can't... :smile:
Reply to novice
Thanks for your advice Novice. I ordered my Flatron 915FT+ from <A HREF="http://www.techonweb.com" target="_new">http://www.techonweb.com</A> and got it for $356 including S&H. That was a site you had given me from another post. See what happens when you visit these chat sites. Everybody learns from each other and saves money to boot. Can't beat that!
Reply to Anonymous
- 0 +
the last time i visit www.techonweb.com the monitor was out of stock ... i couldn't wait so i just ordered it from www.pcnation.com
Reply to novice
if found this thought you should read about 955df
<A HREF="http://www.samsungmonitor.com/newdesign/html/products/955df.htm" target="_new">http://www.samsungmonitor.com/newdesign/html/products/955df.htm</A>
<A HREF="http://www.hitachidisplays.com/products/19_721F.htm" target="_new">http://www.hitachidisplays.com/products/19_721F.htm</A>
also go to this site <A HREF="http://www.monitorworld.com/" target="_new">http://www.monitorworld.com/</A>
Reply to ycs46241
is the hitachi cm721f a flat screen?
Reply to Anonymous
- 0 +
I, too, am shopping for a 19-inch CRT. Is LG 915FT+ as good as their counterparts from Sony and Viewsonic?
Reply to mis3
yeah i think they pretty much are up there with them (probably better)
the only reason i am not considering them is because the monitor is priced too high (unless someone can find me a refurbished one?)
Reply to Anonymous
get 955DF! I have one and it's great! it's the FLAT version of 950p which got the first place by PCWORLD in their 19inch monitor chart!
Reply to Anonymous
it didn't get first place
Reply to Anonymous
There are 1338 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
