Tom's Hardware > Forum > Motherboards & Memory > Asus > Asus A7N8X Deluxe Front Panel Problem
Forum Motherboards & Memory : Asus - Asus A7N8X Deluxe Front Panel Problem
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I need some sort of converter to connect case front panel firewire port
to the board.
Board: Asus A7N8X Deluxe
Case: Coolermaster Centurion
Asus pinout on the board for IEEE1394:
One row of eight:
12345678
Where:
1=Ground
2=Ground
3=TPA+
4=TPA-
5=TPB+
6=TPB-
7=Ground
8=+12V
With the Coolermaster case, there is a lead for connection to board and
front panel firewire. It's not my setup, so I can't look at the cable, so
this is according to their website.
The end of the cable that goes to the front panel doesn't really matter
at it's matched to the front port. The end that is supposed to go to the
motherboard is arranged in two rows of five:
13579
2468A
Where:
1=TPA+
2=TPA-
3=Ground
4=Ground
5=TPB+
6=TPB-
7=+12V
8=+12V
9=Key
A=NC
So what is needed is a converter from the mainboard pins
12345678
to the plug
13579
2468A
I don't have the time (or indeed the inclination as it's not mine!) to
try to botch something up myself.
I can't just repin it like I've done with USB headers (and occasionally
the pins for power/reset buttons etc) because there isn't a 1x8 header
for the motherboard, just the 2x5 on the lead from the front of the case.
Can anyone help at all?
TIA.
Sponsored Links
In article <Xns94C3AABADA04EiamaranNOSPAMhotmail@130.133.1.4>, iamaran
> to the board.
> One row of eight:
> 12345678
> Where:
> 1=Ground
> 2=Ground
> 3=TPA+
> 4=TPA-
> 5=TPB+
> 6=TPB-
> 7=Ground
> 8=+12V
> 13579
> 2468A
> Where:
> 1=TPA+
> 2=TPA-
> 3=Ground
> 4=Ground
> 5=TPB+
> 6=TPB-
> 7=+12V
> 8=+12V
> 9=Key
> A=NC
> 12345678
> to the plug
> 13579
> 2468A
> TIA.
I can't guarantee that the pins from the case will fit in one
of these, this company or probably several large online
electronics companies, have replacement plastic shrouds for
the pins. There is a 1x8 on this page:
http://www.frontx.com/order_c.html
HTH,
Paul
Reply to Paul
nospam@needed.com (Paul) wrote in
news:nospam-0604041146370001@192.168.1.177:
<snip>
> HTH,
> Paul
Thanks Paul.
Reply to Anonymous
There are 805 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
