Archived from groups: microsoft.public.windowsxp.hardware (
More info?)
Hope this helps...
Hi,
I've searched high and low from microsoft to mcafee's
suggestions...the problem lies in the registry (in my case). I was
getting this same error. Also, my event sounds like windows startup,
email, etc sounds were not working either. As it turns out, I had a
similar PC at work and export these two keys to register the MIDI and
default Windows files in order for it to work again. It worked like a
charm. I also had an issue with the windows recorder not
working...again...this import fixed it.
NOTE: My work PC is a win2k Pro and my home PC is a WinXP Home
Edition. Importing the keys below using the win2k registry export
should not cause problems but you should always backup your registry.
Also, some rules to know:
1. If the source file (SF) has keys that exist in the destination
registry (DR), the destination registry will be overwritten with the
new value.
2. If the SF does not have a key that is listed in the DR, the DR
entries will be retained (i.e. not deleted).
3. If the SF has keys that do NOT exist in the DR, it will be added to
the DR.
Here are the 2 keys:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
NT\CurrentVersion\Drivers32]
and
NT\CurrentVersion\drivers.desc]
"shykitty" <shykitty@discussions.microsoft.com> wrote in message news:<3EA8C8A7-6F66-4B19-8585-A3218C0B0811@microsoft.com>...
> Frenchie, I am having the same exact problem that you and willy are having, I
> was just wondering if either one of you got any answers? Any help would be
> appreciated.
> Thanks,
> shykitty
> "Frenchie" wrote:
> > I have had the same problem with the sound test but I
> > only get the "direct play voice setup error code
> > 0x80004005"..I click ok and the sound test exits with no
> > other messages. You can try something that is posted on
> > Microsoft website but it didn't help me.
> > http://support.microsoft.com/default.aspx?scid=kb;en-
> > us;810686&Product=swp
> > I did when the website said to do in the registry but I
> > still get the error code and I can't find anywhere else
> > that would give me the answer to why it is doing it.
> > >-----Original Message-----
> > >Hi there, i am currently unable to complete the windows
> > >xp sound test wizard, i get the message ..."direct play
> > >voice setup error code 0x80004005"... clicking ok then
> > >brings up another dialog box stating "cannot execute
> > >Dpvsetup.exe ".
> > >I have reinstalled the onboard sound drivers, its
> working
> > >fine in all programs until i try to run the wizard, or
> > >use a program like Gamevoice. also reinstalled DirectX 9.
> > >Microphone records sound fine using windows sounds
> > >recorder so i have no idea what to try next
> > >any help would be appreciated
> > >thanks
> > >Willy
