Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I'm back and I have the computer assembled.
Problem I'm having is that I can't get the bios to come up. My
monitor light just keeps flashing as though its in standby mode.
Computer turns on, fans all spin, HD spins, but nothing else. manual
says this Mobo is supposed to tell you if there is no CPU installed,
so I can t imagine that it cant tell me what my problem is. I get no
beeps or anything. Just everything spinning.
I reset the CMOS and the only things I have plugged in are the vid
card (Radeon 9600SE) and the HD (IBM Deskstar 40GB ATA100). The HD is
on IDE1, using the cable that came with the MObo.
And I'm using 1 Corsair CMX512C2PT DIMM. I also just put a brand new
power supply in the case, a Zalman 400w. i've heard problems where
this Mobo is picky with RAM, but shouldnt it atleast boot?
I removed and reinstalled both the RAM and Vid card. I also checked
all of my jumpers and everything appears to be connected right--but
would something like a HD LED prevent a bios from coming up?? Would
connecting the added USB and Firewire cards stop me?? I consider
these part of the Mobo install and not added compoents.
Problems I've had in the past (with other motherbards) involved metal
touching the Mobo and shorting it, but I couldnt even get the mother
to turn on in that instance, so I doubt thats my problem.
HELLLLP!!!
-Bill
HELLLLP!!!
-Bill
