G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have an Asus A7V8X m/b with 256 MB of PC3200 DDR RAM. I have bought
a new processor - an XP 2800+, which runs at FSB of 333 MHz.
However....when you set the processor speed to the correct speed of
2.083 GHz in the bios, I have discovered that the memory is running at
333MHz also, not at 400 MHz (using Sisoft sandra software).
Furthermore, if you set the CPU speed to "manual" and you then set the
external frequency to 166/33, then in the memory speed box, you only
have Auto and 333 available, not 400. How can I set the memory to run
at the correct 400MHz and have the FSB running at 333MHz at the same
time? Anyone else have this problem? Many thanks in anticipation.
John
John
