Tom's Hardware > Forum > Motherboards & Memory > Asus > P4R800-VM Boot problems XP Home
Forum Motherboards & Memory : Asus - P4R800-VM Boot problems XP Home
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Bought a new P4R800-VM (ATI RADEON 9100 IGP) motherboard.
Celeron 2.4Ghz
WinXP Home SP1a. Can boot to CD, load XP, setup, and finish loading XP.
Then,
on first boot, it hangs at the splash screen. The status animation (line
with blue bars) scrolls thru once, and stops near the second pass, and stays
there. I let it sit once overnight, to see if it would continue. No dice.
I can boot to safe mode, but there is nothing wrong in device manager. Only
a few yellow question marks, because of video, sound
not having device drivers yet. And of course, in safe mode, it wont run the
Asus driver disk.
Anyone have any clues? On how to load XP Home SP1 from CD, and then get the
Asus 9100IGP motherboard drivers installed?
Sponsored Links
In article <Zbpfc.51391$467.12144555@news4.srv.hcvlny.cv.net>, "Ken Zito"
> Celeron 2.4Ghz
> Then,
> Asus driver disk.
Did you test the memory before installing the OS ?
(See memtest+ from memtest.org)
One owner of this system had good luck using PC2100 ram.
-VM boards generally don't have a lot of adjustments (in
this case, all you've got is "DRAM CAS Select" [Slow]).
Since there is no voltage adjust or measurement capability
for the DRAM voltage, using PC3200 might be difficult, especially
if the DRAM is expecting 2.6V or a little more, instead of
the 2.5V that is good enough for PC2700 or slower memory.
Without some feedback on what memory timings are being used,
it is hard to tell if the BIOS is actually using what is
contained in the SPD on the DIMM, or is using loose timing
values. A guess would be, since the BIOS offers no adjustments,
it is going to need more work by Asus, before it can read
the SPD in any DIMM and come up with good hardware settings for
the motherboard. Maybe that is why the trick of plugging in a
PC2100 (which has slow numbers stored in the SPD) could be
helping.
http://www.abxzone.com/forums/search.php (search for P4R800-VM)
http://www.abxzone.com/forums/show [...] adid=61383
Good luck,
Paul
Reply to Paul
Also I had DRAM CAS in Bios set to FAST. I just set to slow and same thing
happens.
KZ
Reply to Anonymous
In article <Rivfc.65049$467.13094278@news4.srv.hcvlny.cv.net>, "Ken Zito"
> happens.
> KZ
When a board has no adjustments, the options are:
1) Try what adjustments that are offered. You've done that.
2) Wait for a BIOS version that works. That is a pretty slow
and ineffective solution to the problem, as you don't know
what the release schedule is, or if the problem is known.
3) Change out some component to change the problem. You didn't say
if you were using PC3200 or not. Try a slower stick of memory,
as that is the only way you have of getting a different program
content in the SPD (serial presence detect) EEPROM on the DIMM.
4) Return the motherboard under warranty.
The -VM or -MX boards are typically used by businesses, for mass
deployments where they are trying to cut costs. The person
installing the large number of identical motherboards, experiments
with components at first, to determine what combinations don't work.
They do this for the potential cost saving. For example, multiple
system builders have commented on how little trouble they've had
using P4P800-VM boards, so the -VM boards can be tamed if you are
lucky with your experiments.
For a person who is building just one computer, the temptation to
save money is also there. But the thing is, every subsystem on
the motherboard has some degree of incompatibility. You can either
spend your money on a motherboard with adjustments, or buy a
board without adjustments, and spend your money buying multiple
versions of peripherals or memory, and testing them until you find
some that work.
As a result, if a home builder asks for a recommendation, I'd say
"buy a P4P800 or P4C800 full size board", as there are adjustable
memory timings, and adjustable supply voltages for the components.
The motherboard costs more, but there is a much greater chance the
final product will work properly. If a system builder asks, I'd
say "buy the P4P800-VM", knowing the system builder can amortize
the cost of the component experiments over the large number of
units being deployed.
I put together a system before Christmas for somebody as a gift,
and the system would only run at CAS 2.5, even though I put CAS 2
memory in it. There was nothing I could do about it, as the BIOS
was the un-adjustable kind. You just have to play with them, until
you find something that works (good enough).
This is why, before you buy, it pays to Google the model number,
to see if people are experiencing problems. Also, download the
user manual, to see how many adjustments are in the BIOS. For
the most part, if you do those checks before purchase, there
will be fewer surprises during your build. (There can still
be nasty surprises, but fewer of them.)
It is too bad that all the microATX style boards seem to be
the "unadjustable BIOS" kind. It makes constructing a smaller
home computer that much more difficult.
Use the memtest+ program to test the memory, as my suggestion
is just a theory, and you need to prove that the memory is
the problem, before swapping memories. It could easily be
you have another kind of problem. The memtest+ program is
free.
HTH,
Paul
Reply to Paul
In article <chvfc.65031$467.13089215@news4.srv.hcvlny.cv.net>, "Ken Zito"
> Thanks for the quick reply Paul. I am using PC2100 DDR ram. I have not run a
> memory test on it though. I tried using 2 different PC2100 DIMMS, one used
> and one brand new. Same effect. Sigh...
> Ken
> "Paul" <nospam@needed.com> wrote in message news:nospam-
The memory test doesn't solve your problem, but given that many
people are having issues, it shouldn't be ignored.
As for the driver end of things, can you copy any of the CD onto
your hard drive ?
There are drivers on the ATI web page:
http://www.ati.com/support/drivers [...] submit.y=3
They list a GART driver, display driver, LAN driver, and SMBUS driver.
Asus also has a rolled up driver package in two parts on the download
page, which presumably contains the same content as the 36.7MB of
stuff on the ATI site. The Asus download is 31.4MB, in two sections.
(The servers seem to be pretty heavily loaded right now.)
http://www.asus.it/support/downloa [...] uage=en-us
I don't know if you can do anything with those in Safe Mode or not.
Paul
Reply to Paul
Ken
Reply to Anonymous
Try disabling your CD or DVD drives from BIOS, and see if XP will boot
completely then.
If so, it just another ATAPI glitch with the 9100IGP , others have had it
with certian IDE drives.
news:nospam-1504041258540001@192.168.1.177...
run a
used
> > Ken
> your hard drive ?
http://www.ati.com/support/drivers [...] ype=igp&pr
od=IGPXPdriver&submit.x=11&submit.y=3
http://www.asus.it/support/downloa [...] Type=All&S
Language=en-us
> Paul
Reply to Anonymous
Don't know if this will help you, but I have 2 sticks of generic,
single-sided 256MB PC2100 CAS2 in my P4R800-VM running dual channel. I'm
also using a Celeron 2.6GHz. If you are running more than one stick, have
you tried swapping slots? Perhaps swapping slots might also be worth trying
with a single stick.
Dave
______________________________
Remove "yourclothes" to reply directly.
"Ken Zito" <kzito@ooptonline.net> wrote in message
news:Zbpfc.51391$467.12144555@news4.srv.hcvlny.cv.net...
> Celeron 2.4Ghz
> Then,
stays
Only
the
> Asus driver disk.
the
Reply to Anonymous
There are 643 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
