Archived from groups: alt.comp.periphs.mainboard.asus (
More info?)
Yep, no probs there......
Anyway have now found out what was wrong......
Have always used usb adsl modems til now and have changed to using the
X-modem with a built in Network card in my pc.
Had loads of problems where the card and modem were not talking to each
other.
Main problem was that though the network card was set to obtain an ip
address it just would not.
Tried all sorts of things including setting ip address and stuff manual.
That worked and then stopped.
Tried new cat5 cable and network card, same...
Went into windows XP services and set DHCP client to auto and now the
network card/modem gets an ip address without me having to enter it.
So one problem solved .
Second problem.....
for a while the modem/card would connect automatically(I did not have to
enable the Local area connection)Now I have to all the time.
Any thoughts on this?
Thanks.
"Aldo Larrabiata" <zzz@zorglub.net> wrote in message
news:c6p1ln$jpt$1@news-reader5.wanadoo.fr...
> Do your LANs work _separately_ ?
> On my Mobo (A7N8X Dlx ver 1.04) they do but as soon as I enable them
> together, only the nVidia one is working.
> With both enabled, never ever did I succeed to get anything from the 3Com
> (under 98SE). Didn't try any OS else.
> "Noomie" <noomie@creb.ca> a écrit dans le message news:
> reKjc.36969$Y%6.5047155@wards.force9.net...
> > Yep.
> > Working now but can ony run as 10MB half
> > "Jim in Canada" <warnerjim@msn.com> wrote in message
> > news:8CCjc.288874$Ig.52887@pd7tw2no...
> > > Has your operating system (you did not say which) loaded the correct
> > drivers
> > > for the NIC? My 3COM was recognized as something else under XP before
I
> > > loaded the drivers from the manufacturer's CDRom. Also, did you load
the
> > > correct ASUS motherboard chipset adapters from the MB's CDRom.
> > > Jim
> > > "Noomie" <noomie@creb.ca> wrote in message
> > > news:%LAjc.35544$h44.5246732@stones.force9.net...
> > > > Yes, did that.............
> > > > still the same.
> > > > "dino" <whyme@help.com> wrote in message
> > > > news:ZVzjc.24655$OU.530037@news20.bellglobal.com...
> > > >> did you configure Windows correctly to connect to the net?..it is
> just
> > > >> not
> > > >> an automatic thing sometimes..and if you have switched Ethernet
ports
> > you
> > > >> probably would have to reconfigure
