G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hi there,
Tonight I had a problem with this drive. Whilst installing software using
this drive (F: on my XP Pro system) there was a loud bang and then I
discovered that the disc inside this drive was smashed. I need to know what
I can do to remedy the situation.
I have an LG DVD-ROM GDR8161B as my E: drive (mounted above this one).
These are both located in a tower system above (I assume) my two hard
drives. This system is approx. 1 year old and I think still under warranty
(by a matter of days).
I need to know what I can to clear my problem CD-RW F: CD-RW drive. I think
there is about one-half of a CD-ROM still inside the computer. I assume
this is an enclosed case for this drive (but I can't find documentation on
www.lge.com to support this). The computer seems to be running fine apart
from this. However, the drive door will only open about 1" from the tower
and my concern is with pieces from the CD-ROM falling into the rest of the
system below. If I look at my tower, the top slot is blank, the DVD drive
is next from top, then a blank, and below that the problem CD-RW drive (F.
Next is my floppy a: drive. I expect the two hard drives are below this
assembly at the lower half of the unit.
Is there a way in which I can safely open up the case on this tower AMD
Athlon 2100+ clone-type system to check and remove the offending pieces of
CD-ROM? I will need detailed instructions as I have never attempted
anything like this before. Unfortunately I am unable to contact the vendor
at this time for steps to follow (if appropriate due to possible warranty
issue).
The DVD drive (top at E is functioning fine as are all other parts of this
system (so far as I can tell).
So, any and all comments most welcome. I appreciate all help here. Thanks
in advance.
Lynn
manxcat@sympatico.ca
Hi there,
issue).
in advance.
Lynn
