Tom's Hardware > Forum > Motherboards & Memory > Asus > ASUS P4P800 Deluxe Hard Drive Detection Problem
Forum Motherboards & Memory : Asus - ASUS P4P800 Deluxe Hard Drive Detection Problem
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I've just bought a 160 GB Maxtor DiamondMax Plus9 8MB Cache 7200rpm ATA133
drive but am having problems getting my ASUS P4P800 Deluxe to see it. Can
anyone help?
Cheers in advance
Sponsored Links
I've got a 120 and a 250 working on a P4C800 - what's the problem? Does it
not appear in the bios screen at all? Can you hear / feel it spinning up?
"xyz" <dont@spamme.com> wrote in message
news:c7arh9$fa2$1@news5.svr.pol.co.uk...
> Hi,
> anyone help?
> Cheers in advance
Reply to mc
In article <c7arh9$fa2$1@news5.svr.pol.co.uk>, "xyz" <dont@spamme.com> wrote:
> Hi,
> anyone help?
> Cheers in advance
Does your BIOS have entries like this ?
"Onboard IDE Operate Mode" [Compatible]
"IDE Port Settings" [P-ATA Ports Only]
How you set the IDE Operate Mode is a function of the OS
or OSes you plan on using. The above two settings will
ensure you can see a PATA drive, on either Win98 or WInXP.
The thing is, Win98 doesn't know what SATA is, and the
chip makers decided it would be cool if the SATA drive
was wired in logic, to look like it was one of the PATA
cables. That is called Compatible mode. Since PATA only
supports four drives, in Compatible mode you can have
any mix of pairs of PATA or SATA drives, as long as there
aren't more than four drives involved. (If there was a
way to get a native mode driver, then maybe this could
be changed - I'm just reading the manual :-)
In WinXP, using the Enhanced mode apparently makes the
drives look like they are on the PCI bus. Something that
Win98 wouldn't understand, as normally IDE devices have
fixed I/O addresses for their control. In Enhanced mode,
the [S-ATA] setting is the fastest setting, and will allow
all six drives (2xSATA, 4xPATA) on the Southbridge
to be used.
So, try the above two BIOS settings, as that should at least
make your PATA IDE drives work.
If you are bored, there is an Intel document. It explains
in more technical detail the hardware remapping, if you
are interested.
"ICH5 SATA Programmers Reference Manual"
http://www.intel.com/design/chipse [...] 267102.pdf
HTH,
Paul
Reply to Paul
- 0 +
All good stuff but irrelevant to seing a drive in the BIOS!
Check the SATA data cable is attached correctly AND EITHER SATA power OR
molex power cables
"Paul" <nospam@needed.com> wrote in message
news:nospam-0505041255290001@192.168.1.177...
wrote:
> > Hi,
ATA133
Can
> > anyone help?
> > Cheers in advance
> to be used.
> are interested.
> HTH,
> Paul
Reply to mc
I can hear/feel it spinning up but it doesn't appear in the bios screen at
all.
"MC"
<maxcoppin@-no-spam-please-not-even-a-little-bit-@no@no@no-btinternet.com>
wrote in message news:g%8mc.197$EA6.136@newsfe6-gui.server.ntli.net...
it
> > Hi,
ATA133
Can
> > anyone help?
> > Cheers in advance
Reply to xyz
Tried that - no change. The drive must be faulty.
"MC"
wrote in message news:vEbmc.104$Al1.25@newsfe5-gui.server.ntli.net...
> molex power cables
> wrote:
> > > Hi,
> ATA133
> Can
> > > anyone help?
> > > Cheers in advance
> > to be used.
> > are interested.
> > HTH,
> > Paul
Reply to xyz
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
