Archived from groups: microsoft.public.windows.networking.wireless (More info?)
My existing wireless network was working fine until the laptop hard disk
crashed last week and I'm in the process of rebuilding it. The nework was set
up as follows:
- Laptop running XP Pro, McAfee firewall (trusted IP addresses set).
Connects directly to internet via broadband
- Desktop running XP Home, McAfee firewall (trusted IP addresses set).
Printers directly connected to this machine. Connects to internet through
laptop via wireless network
- Linksys Access Control Point
Both machines can ping each other. Both machines have the same folders set
for sharing.
Laptop can access shared folders on desktop and print through the desktop.
Desktop can 'see' laptop via 'view workgroup computers'. However, when try
to connect to laptop from this screen, via start-run-"cmd" or drive mapping
get error:
"\\Clive-laptop is not accessible. You might not have permission to use this
network resource. Contact the administrator of this server to find out if you
haqve access permissions. Logon failure: the user has not been granted the
requested logon type at this computer."
Having read through postings to this forum, the Guest account has now been
enabled on both computers (though it wasn't originally). This still hasn't
worked. The restrictanonymous and restrictanonymoussam registry keys are
unchanged at 1. The server service is running on both machines.
The problem must be with the laptop as everything worked before the hard
disk crash... Any suggestions?
Many thanks.
Archived from groups: microsoft.public.windows.networking.wireless,microsoft.public.windowsxp.network_web (More info?)
On Mon, 6 Dec 2004 09:52:25 -0800, "Clive" <Clive@discussions.microsoft.com>
>up as follows:
>for sharing.
>get error:
>Many thanks.
Clive,
On the laptop, check to see if Simple File Sharing (Control Panel - Folder
Options - View - Advanced settings) is enabled or disabled. With your LAN, you
need to have SFS enabled.
Did you enable Guest using Start - Run - "cmd", then type "net user guest
/active:yes" in the command window?
On the laptop, check your Local Security Policy (Control Panel - Administrative
Tools) - User Rights Assignment, and look at "Deny access to this computer from
the network". Make sure Guest is not in the list.
Cheers,
Chuck
Paranoia comes from experience - and is not necessarily a bad thing.
Archived from groups: microsoft.public.windowsxp.network_web,microsoft.public.windows.networking.wireless (More info?)
> >up as follows:
> >for sharing.
> >get error:
> >Many thanks.
> Clive,
> Cheers,
> Chuck
Chuck
On the laptop:
1) Simple File Sharing was already enabled
2) Guest was already enabled
3) Guest was not on the "Deny access..." list
So it was not these. By the way, when I type in "Net view clive-laptop" to
the cmd window on the desktop, I get the error "System error 5 has occurred.
Access is denied."
Regards,
Clive.
On the laptop, click Start, click Run, type:
Regedit (hit enter)
Next, locate HKLM\System\CurrentControlSet\Control\Lsa
Ensure that "RestrictAnonymous" is set to 0.
Close and reboot.
That should solve it.
Carey
"Clive" <Clive@discussions.microsoft.com> wrote in message
news:310DDAFF-3797-4360-9FEF-8DE805B96629@microsoft.com...
>> >was set
>> >up as follows:
>> >through
>> >set
>> >for sharing.
>> >desktop.
>> >try
>> >mapping
>> >get error:
>> >this
>> >if you
>> >the
>> >been
>> >hasn't
>> >are
>> >Many thanks.
>> Clive,
>> Folder
>> LAN, you
>> Administrative
>> computer from
>> Cheers,
>> Chuck
> Chuck
> On the laptop:
> to
> occurred.
> Access is denied."
> Regards,
> Clive.
Carey
Thanks for the suggestion. I've set "RestrictAnonymous" to 0 on both
machines and rebooted. I still have the problem.
Regards,
Clive.
> Regedit (hit enter)
> Close and reboot.
> Carey
> >> >was set
> >> >up as follows:
> >> >through
> >> >set
> >> >for sharing.
> >> >desktop.
> >> >try
> >> >mapping
> >> >get error:
> >> >this
> >> >if you
> >> >the
> >> >been
> >> >hasn't
> >> >are
> >> >Many thanks.
> >> Clive,
> >> Folder
> >> LAN, you
> >> Administrative
> >> computer from
> >> Cheers,
> >> Chuck
> > Chuck
> > On the laptop:
> > to
> > occurred.
> > Access is denied."
> > Regards,
> > Clive.
In the network properties of each machine, do you have Client for MS
Networks and File and Printer Sharing installed (Also, on the xp pc, do they
have checks next to them?)
Carey
news:45509D70-4161-4357-87DD-CE2411A77B55@microsoft.com...
> Carey
> Regards,
> Clive.
>> Regedit (hit enter)
>> Close and reboot.
>> Carey
>> >> >disk
>> >> >was set
>> >> >up as follows:
>> >> >set).
>> >> >through
>> >> >folders
>> >> >set
>> >> >for sharing.
>> >> >desktop.
>> >> >when
>> >> >try
>> >> >mapping
>> >> >get error:
>> >> >use
>> >> >this
>> >> >out
>> >> >if you
>> >> >granted
>> >> >the
>> >> >been
>> >> >hasn't
>> >> >are
>> >> >hard
>> >> >Many thanks.
>> >> Clive,
>> >> Folder
>> >> LAN, you
>> >> guest
>> >> Administrative
>> >> computer from
>> >> Cheers,
>> >> Chuck
>> > Chuck
>> > On the laptop:
>> > clive-laptop"
>> > to
>> > occurred.
>> > Access is denied."
>> > Regards,
>> > Clive.
Carey
Thanks for the suggestion. I've looked at both machines and Client for MS
Networks and File and Printer Sharing were installed and they had checks next
to them. So, I still have the problem.
Regards,
Clive.
> Carey
> > Carey
> > Regards,
> > Clive.
> >> Regedit (hit enter)
> >> Close and reboot.
> >> Carey
> >> >> >disk
> >> >> >was set
> >> >> >up as follows:
> >> >> >set).
> >> >> >through
> >> >> >folders
> >> >> >set
> >> >> >for sharing.
> >> >> >desktop.
> >> >> >when
> >> >> >try
> >> >> >mapping
> >> >> >get error:
> >> >> >use
> >> >> >this
> >> >> >out
> >> >> >if you
> >> >> >granted
> >> >> >the
> >> >> >been
> >> >> >hasn't
> >> >> >are
> >> >> >hard
> >> >> >Many thanks.
> >> >> Clive,
> >> >> Folder
> >> >> LAN, you
> >> >> guest
> >> >> Administrative
> >> >> computer from
> >> >> Cheers,
> >> >> Chuck
> >> > Chuck
> >> > On the laptop:
> >> > clive-laptop"
> >> > to
> >> > occurred.
> >> > Access is denied."
> >> > Regards,
> >> > Clive.
Please send me the IPCONFIG info from each PC
Click Start, click Run, type: cmd (and hit enter)
Type: ipconfig /all >c:\ipconfig.txt (and hit enter)
Use Notepad to open c:\ipconfig.txt and copy and paste entire contents into
your next post.
Thanks,
Carey
news
E32A703-E9C2-48A8-BAC1-B6EDB83B73DC@microsoft.com...
> Carey
> next
> Regards,
> Clive.
>> they
>> Carey
>> > Carey
>> > Regards,
>> > Clive.
>> >> Regedit (hit enter)
>> >> Close and reboot.
>> >> Carey
>> >> >> >hard
>> >> >> >disk
>> >> >> >nework
>> >> >> >was set
>> >> >> >up as follows:
>> >> >> >set).
>> >> >> >set).
>> >> >> >through
>> >> >> >folders
>> >> >> >set
>> >> >> >for sharing.
>> >> >> >desktop.
>> >> >> >when
>> >> >> >try
>> >> >> >drive
>> >> >> >mapping
>> >> >> >get error:
>> >> >> >to
>> >> >> >use
>> >> >> >this
>> >> >> >out
>> >> >> >if you
>> >> >> >granted
>> >> >> >the
>> >> >> >now
>> >> >> >been
>> >> >> >still
>> >> >> >hasn't
>> >> >> >keys
>> >> >> >are
>> >> >> >the
>> >> >> >hard
>> >> >> >Many thanks.
>> >> >> Clive,
>> >> >> Folder
>> >> >> your
>> >> >> LAN, you
>> >> >> guest
>> >> >> Administrative
>> >> >> computer from
>> >> >> Cheers,
>> >> >> Chuck
>> >> >> thing.
>> >> > Chuck
>> >> > On the laptop:
>> >> > clive-laptop"
>> >> > to
>> >> > occurred.
>> >> > Access is denied."
>> >> > Regards,
>> >> > Clive.
Carey
ipconfig /all for the laptop as follows:
Windows IP Configuration
Host Name . . . . . . . . . . . . : CLIVE-LAPTOP
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : Yes
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Network Bridge (Network Bridge) 6:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : MAC Bridge Miniport
Physical Address. . . . . . . . . : 02-04-23-4C-58-FF
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
PPP adapter BT Broadband:
Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
Physical Address. . . . . . . . . : 00-53-45-00-00-00
IP Address. . . . . . . . . . . . : 81.157.0.215
Subnet Mask . . . . . . . . . . . : 255.255.255.255
Default Gateway . . . . . . . . . : 81.157.0.215
DNS Servers . . . . . . . . . . . : 194.74.65.69
194.72.9.38
ipconfig /all for the desktop as follows:
Host Name . . . . . . . . . . . . : TAYLOR
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
Ethernet adapter Wireless Network Connection 3:
Description . . . . . . . . . . . : Instant Wireless USB Network
Adapter ver.2.6
Physical Address. . . . . . . . . : 00-06-25-0E-58-8A
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.1.101
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DNS Servers . . . . . . . . . . . : 192.168.1.1
Lease Obtained. . . . . . . . . . : 13 December 2004 07:35:25
Lease Expires . . . . . . . . . . : 13 December 2004 07:40:25
Regards
Clive.
> your next post.
> Thanks,
> Carey
> news
> > Carey
> > next
> > Regards,
> > Clive.
> >> they
> >> Carey
> >> > Carey
> >> > Regards,
> >> > Clive.
> >> >> Regedit (hit enter)
> >> >> Close and reboot.
> >> >> Carey
> >> >> >> >hard
> >> >> >> >disk
> >> >> >> >nework
> >> >> >> >was set
> >> >> >> >up as follows:
> >> >> >> >set).
> >> >> >> >set).
> >> >> >> >through
> >> >> >> >folders
> >> >> >> >set
> >> >> >> >for sharing.
> >> >> >> >desktop.
> >> >> >> >when
> >> >> >> >try
> >> >> >> >drive
> >> >> >> >mapping
> >> >> >> >get error:
> >> >> >> >to
> >> >> >> >use
> >> >> >> >this
> >> >> >> >out
> >> >> >> >if you
> >> >> >> >granted
> >> >> >> >the
> >> >> >> >now
> >> >> >> >been
> >> >> >> >still
> >> >> >> >hasn't
> >> >> >> >keys
> >> >> >> >are
> >> >> >> >the
> >> >> >> >hard
> >> >> >> >Many thanks.
> >> >> >> Clive,
> >> >> >> Folder
> >> >> >> your
> >> >> >> LAN, you
> >> >> >> guest
> >> >> >> Administrative
> >> >> >> computer from
> >> >> >> Cheers,
> >> >> >> Chuck
> >> >> >> thing.
> >> >> > Chuck
> >> >> > On the laptop:
> >> >> > clive-laptop"
> >> >> > to
> >> >> > occurred.
> >> >> > Access is denied."
> >> >> > Regards,
> >> >> > Clive.
You're not running a router? You're using two NICs and ICS?
news:890AB376-13E6-42F5-A659-97B3D6BC310F@microsoft.com...
> Carey
> 194.72.9.38
> Adapter ver.2.6
> Regards
> Clive.
>> into
>> your next post.
>> Thanks,
>> Carey
>> news
>> > Carey
>> > MS
>> > checks
>> > next
>> > Regards,
>> > Clive.
>> >> do
>> >> they
>> >> Carey
>> >> > Carey
>> >> > both
>> >> > Regards,
>> >> > Clive.
>> >> >> Regedit (hit enter)
>> >> >> Close and reboot.
>> >> >> Carey
>> >> >> >> >hard
>> >> >> >> >disk
>> >> >> >> >nework
>> >> >> >> >was set
>> >> >> >> >up as follows:
>> >> >> >> >set).
>> >> >> >> >addresses
>> >> >> >> >set).
>> >> >> >> >internet
>> >> >> >> >through
>> >> >> >> >folders
>> >> >> >> >set
>> >> >> >> >for sharing.
>> >> >> >> >the
>> >> >> >> >desktop.
>> >> >> >> >However,
>> >> >> >> >when
>> >> >> >> >try
>> >> >> >> >drive
>> >> >> >> >mapping
>> >> >> >> >get error:
>> >> >> >> >permission
>> >> >> >> >to
>> >> >> >> >use
>> >> >> >> >this
>> >> >> >> >find
>> >> >> >> >out
>> >> >> >> >if you
>> >> >> >> >granted
>> >> >> >> >the
>> >> >> >> >has
>> >> >> >> >now
>> >> >> >> >been
>> >> >> >> >still
>> >> >> >> >hasn't
>> >> >> >> >registry
>> >> >> >> >keys
>> >> >> >> >are
>> >> >> >> >machines.
>> >> >> >> >the
>> >> >> >> >hard
>> >> >> >> >Many thanks.
>> >> >> >> Clive,
>> >> >> >> Panel -
>> >> >> >> Folder
>> >> >> >> With
>> >> >> >> your
>> >> >> >> LAN, you
>> >> >> >> user
>> >> >> >> guest
>> >> >> >> Administrative
>> >> >> >> this
>> >> >> >> computer from
>> >> >> >> Cheers,
>> >> >> >> Chuck
>> >> >> >> thing.
>> >> >> > Chuck
>> >> >> > On the laptop:
>> >> >> > clive-laptop"
>> >> >> > to
>> >> >> > has
>> >> >> > occurred.
>> >> >> > Access is denied."
>> >> >> > Regards,
>> >> >> > Clive.
Sorry, ignore that last message about restrictanonymous.. I read further
down the thread and saw we went there already.
I am curious how you have these machines configured. You have a wireless USB
NIC on the desktop, and you have the cable modem plugged directly into the
laptop and are using another NIC on the laptop to share that connection.
Does the laptop have built-in wireless and you are in Ad-Hoc mode with the
wireless NICs?
That's just bad jo-jo with regards to wireless security.
Although the Node Type shouldn't matter, I'd feel better seeing your Node
Type set to Unknown. To do this, on each PC, run the registry editor, open
this key:
HLM\System\CurrentControlSet\Services\Netbt\Parameters
and delete these values if they're present:
NodeType
DhcpNodeType
Reboot, then try IPCONFIG /ALL again to see if the Node Type has changed to
UNKNOWN on both PCs. If so, try to access the network again.
Carey
> Carey
> 194.72.9.38
> Adapter ver.2.6
> Regards
> Clive.
>> into
>> your next post.
>> Thanks,
>> Carey
>> news
>> > Carey
>> > MS
>> > checks
>> > next
>> > Regards,
>> > Clive.
>> >> do
>> >> they
>> >> Carey
>> >> > Carey
>> >> > both
>> >> > Regards,
>> >> > Clive.
>> >> >> Regedit (hit enter)
>> >> >> Close and reboot.
>> >> >> Carey
>> >> >> >> >hard
>> >> >> >> >disk
>> >> >> >> >nework
>> >> >> >> >was set
>> >> >> >> >up as follows:
>> >> >> >> >set).
>> >> >> >> >addresses
>> >> >> >> >set).
>> >> >> >> >internet
>> >> >> >> >through
>> >> >> >> >folders
>> >> >> >> >set
>> >> >> >> >for sharing.
>> >> >> >> >the
>> >> >> >> >desktop.
>> >> >> >> >However,
>> >> >> >> >when
>> >> >> >> >try
>> >> >> >> >drive
>> >> >> >> >mapping
>> >> >> >> >get error:
>> >> >> >> >permission
>> >> >> >> >to
>> >> >> >> >use
>> >> >> >> >this
>> >> >> >> >find
>> >> >> >> >out
>> >> >> >> >if you
>> >> >> >> >granted
>> >> >> >> >the
>> >> >> >> >has
>> >> >> >> >now
>> >> >> >> >been
>> >> >> >> >still
>> >> >> >> >hasn't
>> >> >> >> >registry
>> >> >> >> >keys
>> >> >> >> >are
>> >> >> >> >machines.
>> >> >> >> >the
>> >> >> >> >hard
>> >> >> >> >Many thanks.
>> >> >> >> Clive,
>> >> >> >> Panel -
>> >> >> >> Folder
>> >> >> >> With
>> >> >> >> your
>> >> >> >> LAN, you
>> >> >> >> user
>> >> >> >> guest
>> >> >> >> Administrative
>> >> >> >> this
>> >> >> >> computer from
>> >> >> >> Cheers,
>> >> >> >> Chuck
>> >> >> >> thing.
>> >> >> > Chuck
>> >> >> > On the laptop:
>> >> >> > clive-laptop"
>> >> >> > to
>> >> >> > has
>> >> >> > occurred.
>> >> >> > Access is denied."
>> >> >> > Regards,
>> >> >> > Clive.
Carey
The original configuration was laptop with built-in wireless, desktop with
Linksys wireless USB adapter and Linksys wireless broadband router (acting as
an access control point only). The wireless network was set up with a unique
SSID (not "Linksys"!) and WEP key, so my understanding was that security was
okay. Initially, I ran this for file and printer sharing only until I was
due to get broadband.
However, when broadband arrived a couple of months ago, it came with a USB
modem, so I couldn't plug the Linksys wireless broadband router into it. As
a temporary measure, I connected the broadband modem to the laptop, so the
Linksys router continued to act as an access point only. The bridge on the
laptop was configured for wireless and local area connection so that I could
connect directly to the Linksys box to configure/reconfigure when necessary.
This set up worked until the laptop hard disk crashed.
I've made the changes to both machines -- NodeType was not present on either
but DhcpNodeType has been set to zero and the machines rebooted. Ipconfig
now shows "Node Type: Unknown" on both machines.
Regards,
Clive.
PS In the spirit of trying to keep things simple, I had intended changing
the USB broadband modem/Linksys router combination for an integrated wireless
router/modem in the New Year (broadband modems with Ethernet ports seem
almost as expensive and integrated units in the UK). I'd value your thoughts.
> wireless NICs?
> this key:
> NodeType
> DhcpNodeType
> Carey
> > Carey
> > 194.72.9.38
> > Adapter ver.2.6
> > Regards
> > Clive.
> >> into
> >> your next post.
> >> Thanks,
> >> Carey
> >> news
> >> > Carey
> >> > MS
> >> > checks
> >> > next
> >> > Regards,
> >> > Clive.
> >> >> do
> >> >> they
> >> >> Carey
> >> >> > Carey
> >> >> > both
> >> >> > Regards,
> >> >> > Clive.
> >> >> >> Regedit (hit enter)
> >> >> >> Close and reboot.
> >> >> >> Carey
> >> >> >> >> >hard
> >> >> >> >> >disk
> >> >> >> >> >nework
> >> >> >> >> >was set
> >> >> >> >> >up as follows:
> >> >> >> >> >set).
> >> >> >> >> >addresses
> >> >> >> >> >set).
> >> >> >> >> >internet
> >> >> >> >> >through
> >> >> >> >> >folders
> >> >> >> >> >set
> >> >> >> >> >for sharing.
> >> >> >> >> >the
> >> >> >> >> >desktop.
> >> >> >> >> >However,
> >> >> >> >> >when
> >> >> >> >> >try
> >> >> >> >> >drive
> >> >> >> >> >mapping
> >> >> >> >> >get error:
> >> >> >> >> >permission
> >> >> >> >> >to
> >> >> >> >> >use
> >> >> >> >> >this
> >> >> >> >> >find
> >> >> >> >> >out
> >> >> >> >> >if you
> >> >> >> >> >granted
> >> >> >> >> >the
> >> >> >> >> >has
> >> >> >> >> >now
> >> >> >> >> >been
> >> >> >> >> >still
> >> >> >> >> >hasn't
> >> >> >> >> >registry
> >> >> >> >> >keys
> >> >> >> >> >are
> >> >> >> >> >machines.
> >> >> >> >> >the
> >> >> >> >> >hard
> >> >> >> >> >Many thanks.
> >> >> >> >> Clive,
> >> >> >> >> Panel -
> >> >> >> >> Folder
> >> >> >> >> With
> >> >> >> >> your
> >> >> >> >> LAN, you
> >> >> >> >> user
> >> >> >> >> guest
> >> >> >> >> Administrative
> >> >> >> >> this
> >> >> >> >> computer from
> >> >> >> >> Cheers,
> >> >> >> >> Chuck
> >> >> >> >> thing.
> >> >> >> > Chuck
> >> >> >> > On the laptop:
> >> >> >> > clive-laptop"
> >> >> >> > to
> >> >> >> > has
> >> >> >> > occurred.
> >> >> >> > Access is denied."
> >> >> >> > Regards,
> >> >> >> > Clive.
If I understand correctly, the laptop has XP PRO and is inaccessible from
the desktop which has XP HOME.
Windows XP Pro: two policies can be found in Control Panel, Performance and
Maintenance, Administrative Tools, Local Security Policy (or click Start,
Run, and enter: gpedit.msc), expand Computer configuration, Windows
settings, Security settings, Local policies, Assign user rights, then search
for the two policies named:
a.. Access this computer from the network
b.. Deny access to this computer from the network
Double-click on the second one. It usually contains a SUPPORT user. Some
third party software adds Guest or some other user or group here.
If Guest is included, guest access (all users who do not have an account
with the same username and password on the target computer) from other
computers is not possible and yields the above-mentioned error message.
Remove Guest and all other groups or users who should be able to access this
computer over the network. The SUPPORT user entry may remain in place.
In the policy, "Access this computer from the network" make sure that the
group Everyone is included. If not, add it as a new, last line under the
other entries.
(above copied from: http://www.michna.com/kb/wxnet.htm)
Let me know if this helps.
Carey
news:CF37B563-9C23-4864-BF39-4B9E726F9BE3@microsoft.com...
> Carey
> as
> unique
> was
> As
> the
> could
> necessary.
> either
> Regards,
> Clive.
> wireless
> thoughts.
>> USB
>> the
>> the
>> wireless NICs?
>> open
>> this key:
>> NodeType
>> DhcpNodeType
>> to
>> Carey
>> > Carey
>> > 194.72.9.38
>> > Adapter ver.2.6
>> > Regards
>> > Clive.
>> >> into
>> >> your next post.
>> >> Thanks,
>> >> Carey
>> >> news
>> >> > Carey
>> >> > for
>> >> > MS
>> >> > checks
>> >> > next
>> >> > Regards,
>> >> > Clive.
>> >> >> MS
>> >> >> pc,
>> >> >> do
>> >> >> they
>> >> >> Carey
>> >> >> > Carey
>> >> >> > both
>> >> >> > Regards,
>> >> >> > Clive.
>> >> >> >> Regedit (hit enter)
>> >> >> >> Close and reboot.
>> >> >> >> Carey
>> >> >> >> >> >laptop
>> >> >> >> >> >hard
>> >> >> >> >> >disk
>> >> >> >> >> >The
>> >> >> >> >> >nework
>> >> >> >> >> >was set
>> >> >> >> >> >up as follows:
>> >> >> >> >> >addresses
>> >> >> >> >> >set).
>> >> >> >> >> >addresses
>> >> >> >> >> >set).
>> >> >> >> >> >internet
>> >> >> >> >> >through
>> >> >> >> >> >same
>> >> >> >> >> >folders
>> >> >> >> >> >set
>> >> >> >> >> >for sharing.
>> >> >> >> >> >through
>> >> >> >> >> >the
>> >> >> >> >> >desktop.
>> >> >> >> >> >However,
>> >> >> >> >> >when
>> >> >> >> >> >try
>> >> >> >> >> >or
>> >> >> >> >> >drive
>> >> >> >> >> >mapping
>> >> >> >> >> >get error:
>> >> >> >> >> >permission
>> >> >> >> >> >to
>> >> >> >> >> >use
>> >> >> >> >> >this
>> >> >> >> >> >to
>> >> >> >> >> >find
>> >> >> >> >> >out
>> >> >> >> >> >if you
>> >> >> >> >> >been
>> >> >> >> >> >granted
>> >> >> >> >> >the
>> >> >> >> >> >account
>> >> >> >> >> >has
>> >> >> >> >> >now
>> >> >> >> >> >been
>> >> >> >> >> >This
>> >> >> >> >> >still
>> >> >> >> >> >hasn't
>> >> >> >> >> >registry
>> >> >> >> >> >keys
>> >> >> >> >> >are
>> >> >> >> >> >machines.
>> >> >> >> >> >before
>> >> >> >> >> >the
>> >> >> >> >> >hard
>> >> >> >> >> >Many thanks.
>> >> >> >> >> Clive,
>> >> >> >> >> Panel -
>> >> >> >> >> Folder
>> >> >> >> >> With
>> >> >> >> >> your
>> >> >> >> >> LAN, you
>> >> >> >> >> "net
>> >> >> >> >> user
>> >> >> >> >> guest
>> >> >> >> >> Panel -
>> >> >> >> >> Administrative
>> >> >> >> >> this
>> >> >> >> >> computer from
>> >> >> >> >> Cheers,
>> >> >> >> >> Chuck
>> >> >> >> >> thing.
>> >> >> >> > Chuck
>> >> >> >> > On the laptop:
>> >> >> >> > clive-laptop"
>> >> >> >> > to
>> >> >> >> > has
>> >> >> >> > occurred.
>> >> >> >> > Access is denied."
>> >> >> >> > Regards,
>> >> >> >> > Clive.
Carey
Some success!
The "Deny access.." policy only had a SUPPORT user in it BUT the "Access
this computer..." policy was blank. I added a group "Everyone" and can now
see the laptop from the desktop. Thanks for getting me this far.
However, the desktop cannot see the broadband connection. I've rerun the
network wizard on the desktop just in case and reselected "This computer
connects to the Internet through another computer". I've rebooted both
machines. The laptop is connected to broadband but the desktop shows a
standard Internet Connection icon which is "Disconnected". Previously, I
could see the broadband icon on the desktop.
FYI -- the broadband advanced properties on the laptop have been set for
internet connection sharing (all three boxes checked). Nothing is checked in
the "settings" option. I didn't set anything via this option before (so I
can't say whether anything was checked previously or not).
Thanks
Clive.
> other entries.
> Carey
> > Carey
> > as
> > unique
> > was
> > As
> > the
> > could
> > necessary.
> > either
> > Regards,
> > Clive.
> > wireless
> > thoughts.
> >> USB
> >> the
> >> the
> >> wireless NICs?
> >> open
> >> this key:
> >> NodeType
> >> DhcpNodeType
> >> to
> >> Carey
> >> > Carey
> >> > 194.72.9.38
> >> > Adapter ver.2.6
> >> > Regards
> >> > Clive.
> >> >> into
> >> >> your next post.
> >> >> Thanks,
> >> >> Carey
> >> >> news
> >> >> > Carey
> >> >> > for
> >> >> > MS
> >> >> > checks
> >> >> > next
> >> >> > Regards,
> >> >> > Clive.
> >> >> >> MS
> >> >> >> pc,
> >> >> >> do
> >> >> >> they
> >> >> >> Carey
> >> >> >> > Carey
> >> >> >> > both
> >> >> >> > Regards,
> >> >> >> > Clive.
> >> >> >> >> Regedit (hit enter)
> >> >> >> >> Close and reboot.
> >> >> >> >> Carey
> >> >> >> >> >> >laptop
> >> >> >> >> >> >hard
> >> >> >> >> >> >disk
> >> >> >> >> >> >The
> >> >> >> >> >> >nework
> >> >> >> >> >> >was set
> >> >> >> >> >> >up as follows:
> >> >> >> >> >> >addresses
> >> >> >> >> >> >set).
> >> >> >> >> >> >addresses
> >> >> >> >> >> >set).
> >> >> >> >> >> >internet
> >> >> >> >> >> >through
> >> >> >> >> >> >same
> >> >> >> >> >> >folders
> >> >> >> >> >> >set
> >> >> >> >> >> >for sharing.
> >> >> >> >> >> >through
> >> >> >> >> >> >the
> >> >> >> >> >> >desktop.
> >> >> >> >> >> >However,
> >> >> >> >> >> >when
> >> >> >> >> >> >try
> >> >> >> >> >> >or
> >> >> >> >> >> >drive
> >> >> >> >> >> >mapping
> >> >> >> >> >> >get error:
> >> >> >> >> >> >permission
> >> >> >> >> >> >to
> >> >> >> >> >> >use
> >> >> >> >> >> >this
> >> >> >> >> >> >to
> >> >> >> >> >> >find
> >> >> >> >> >> >out
> >> >> >> >> >> >if you
> >> >> >> >> >> >been
> >> >> >> >> >> >granted
> >> >> >> >> >> >the
> >> >> >> >> >> >account
> >> >> >> >> >> >has
> >> >> >> >> >> >now
> >> >> >> >> >> >been
> >> >> >> >> >> >This
> >> >> >> >> >> >still
> >> >> >> >> >> >hasn't
> >> >> >> >> >> >registry
> >> >> >> >> >> >keys
> >> >> >> >> >> >are
> >> >> >> >> >> >machines.
> >> >> >> >> >> >before
> >> >> >> >> >> >the
> >> >> >> >> >> >hard
> >> >> >> >> >> >Many thanks.
> >> >> >> >> >> Clive,
> >> >> >> >> >> Panel -
> >> >> >> >> >> Folder
> >> >> >> >> >> With
> >> >> >> >> >> your
> >> >> >> >> >> LAN, you
> >> >> >> >> >> "net
> >> >> >> >> >> user
> >> >> >> >> >> guest
> >> >> >> >> >> Panel -
> >> >> >> >> >> Administrative
> >> >> >> >> >> this
> >> >> >> >> >> computer from
> >> >> >> >> >> Cheers,
> >> >> >> >> >> Chuck
> >> >> >> >> >> thing.
> >> >> >> >> > Chuck
> >> >> >> >> > On the laptop:
> >> >> >> >> > clive-laptop"
> >> >> >> >> > to
> >> >> >> >> > has
> >> >> >> >> > occurred.
> >> >> >> >> > Access is denied."
> >> >> >> >> > Regards,
> >> >> >> >> > Clive.
Not sure if this will help but I would delete the network bridge
I would Disable DHCP in the router
If you are going to us ICS then Windows ICS will give out the IP address
If you are going to use a network bridge then you would have to but in the
Default Gateway in witch I think? Is the Ip address of the USB modem and DNS
Severs from USB modem you as well the Network card in the desktop would have
to be set up manual with ip address as well Default Gateway and DNS Severs I
am not sure if Default Gateway Ip address Is that USB modem or the ip off
the network bridge
Steve
news:8052B59E-DF77-434C-AF34-382E69AB74F8@microsoft.com...
> Carey
> Some success!
now
in
> Thanks
> Clive.
from
and
Start,
search
this
the
> > other entries.
> > Carey
> > > Carey
with
(acting
> > > as
> > > unique
security
> > > was
was
USB
it.
> > > As
the
on
> > > the
> > > could
> > > necessary.
> > > either
Ipconfig
> > > Regards,
> > > Clive.
changing
> > > wireless
seem
> > > thoughts.
further
wireless
> > >> USB
into
> > >> the
connection.
with
> > >> the
> > >> wireless NICs?
Node
> > >> open
> > >> this key:
> > >> NodeType
> > >> DhcpNodeType
changed
> > >> to
> > >> Carey
> > >> > Carey
> > >> > 194.72.9.38
Network
> > >> > Adapter ver.2.6
07:35:25
07:40:25
> > >> > Regards
> > >> > Clive.
contents
> > >> >> into
> > >> >> your next post.
> > >> >> Thanks,
> > >> >> Carey
> > >> >> news
> > >> >> > Carey
Client
> > >> >> > for
> > >> >> > MS
had
> > >> >> > checks
> > >> >> > next
> > >> >> > Regards,
> > >> >> > Clive.
for
> > >> >> >> MS
xp
> > >> >> >> pc,
> > >> >> >> do
> > >> >> >> they
> > >> >> >> Carey
> > >> >> >> > Carey
on
> > >> >> >> > both
> > >> >> >> > Regards,
> > >> >> >> > Clive.
> > >> >> >> >> Regedit (hit enter)
> > >> >> >> >> Close and reboot.
> > >> >> >> >> Carey
> > >> >> >> >> >> >laptop
> > >> >> >> >> >> >hard
> > >> >> >> >> >> >disk
it.
> > >> >> >> >> >> >The
> > >> >> >> >> >> >nework
> > >> >> >> >> >> >was set
> > >> >> >> >> >> >up as follows:
> > >> >> >> >> >> >addresses
> > >> >> >> >> >> >set).
> > >> >> >> >> >> >addresses
> > >> >> >> >> >> >set).
to
> > >> >> >> >> >> >internet
> > >> >> >> >> >> >through
the
> > >> >> >> >> >> >same
> > >> >> >> >> >> >folders
> > >> >> >> >> >> >set
> > >> >> >> >> >> >for sharing.
> > >> >> >> >> >> >through
> > >> >> >> >> >> >the
> > >> >> >> >> >> >desktop.
> > >> >> >> >> >> >However,
> > >> >> >> >> >> >when
> > >> >> >> >> >> >try
start-run-"cmd"
> > >> >> >> >> >> >or
> > >> >> >> >> >> >drive
> > >> >> >> >> >> >mapping
> > >> >> >> >> >> >get error:
> > >> >> >> >> >> >permission
> > >> >> >> >> >> >to
> > >> >> >> >> >> >use
> > >> >> >> >> >> >this
server
> > >> >> >> >> >> >to
> > >> >> >> >> >> >find
> > >> >> >> >> >> >out
> > >> >> >> >> >> >if you
not
> > >> >> >> >> >> >been
> > >> >> >> >> >> >granted
> > >> >> >> >> >> >the
> > >> >> >> >> >> >account
> > >> >> >> >> >> >has
> > >> >> >> >> >> >now
> > >> >> >> >> >> >been
> > >> >> >> >> >> >This
> > >> >> >> >> >> >still
> > >> >> >> >> >> >hasn't
> > >> >> >> >> >> >registry
> > >> >> >> >> >> >keys
> > >> >> >> >> >> >are
> > >> >> >> >> >> >machines.
> > >> >> >> >> >> >before
> > >> >> >> >> >> >the
> > >> >> >> >> >> >hard
> > >> >> >> >> >> >Many thanks.
> > >> >> >> >> >> Clive,
(Control
> > >> >> >> >> >> Panel -
> > >> >> >> >> >> Folder
disabled.
> > >> >> >> >> >> With
> > >> >> >> >> >> your
> > >> >> >> >> >> LAN, you
> > >> >> >> >> >> "net
> > >> >> >> >> >> user
> > >> >> >> >> >> guest
> > >> >> >> >> >> Panel -
> > >> >> >> >> >> Administrative
to
> > >> >> >> >> >> this
> > >> >> >> >> >> computer from
> > >> >> >> >> >> Cheers,
> > >> >> >> >> >> Chuck
bad
> > >> >> >> >> >> thing.
> > >> >> >> >> > Chuck
> > >> >> >> >> > On the laptop:
> > >> >> >> >> > clive-laptop"
> > >> >> >> >> > to
error 5
> > >> >> >> >> > has
> > >> >> >> >> > occurred.
> > >> >> >> >> > Access is denied."
> > >> >> >> >> > Regards,
> > >> >> >> >> > Clive.
What is the IP Address of the router?
Carey
> Carey
> Some success!
> now
> in
> Thanks
> Clive.
>> and
>> search
>> this
>> other entries.
>> Carey
>> > Carey
>> > with
>> > (acting
>> > as
>> > unique
>> > security
>> > was
>> > was
>> > USB
>> > it.
>> > As
>> > the
>> > the
>> > could
>> > necessary.
>> > either
>> > Ipconfig
>> > Regards,
>> > Clive.
>> > changing
>> > wireless
>> > thoughts.
>> >> further
>> >> wireless
>> >> USB
>> >> the
>> >> connection.
>> >> the
>> >> wireless NICs?
>> >> Node
>> >> open
>> >> this key:
>> >> NodeType
>> >> DhcpNodeType
>> >> changed
>> >> to
>> >> Carey
>> >> > Carey
>> >> > 194.72.9.38
>> >> > Network
>> >> > Adapter ver.2.6
>> >> > Regards
>> >> > Clive.
>> >> >> contents
>> >> >> into
>> >> >> your next post.
>> >> >> Thanks,
>> >> >> Carey
>> >> >> news
>> >> >> > Carey
>> >> >> > Client
>> >> >> > for
>> >> >> > MS
>> >> >> > checks
>> >> >> > next
>> >> >> > Regards,
>> >> >> > Clive.
>> >> >> >> for
>> >> >> >> MS
>> >> >> >> pc,
>> >> >> >> do
>> >> >> >> they
>> >> >> >> Carey
>> >> >> >> > Carey
>> >> >> >> > on
>> >> >> >> > both
>> >> >> >> > Regards,
>> >> >> >> > Clive.
>> >> >> >> >> Regedit (hit enter)
>> >> >> >> >> Close and reboot.
>> >> >> >> >> Carey
>> >> >> >> >> >> >laptop
>> >> >> >> >> >> >hard
>> >> >> >> >> >> >disk
>> >> >> >> >> >> >it.
>> >> >> >> >> >> >The
>> >> >> >> >> >> >nework
>> >> >> >> >> >> >was set
>> >> >> >> >> >> >up as follows:
>> >> >> >> >> >> >addresses
>> >> >> >> >> >> >set).
>> >> >> >> >> >> >addresses
>> >> >> >> >> >> >set).
>> >> >> >> >> >> >internet
>> >> >> >> >> >> >through
>> >> >> >> >> >> >the
>> >> >> >> >> >> >same
>> >> >> >> >> >> >folders
>> >> >> >> >> >> >set
>> >> >> >> >> >> >for sharing.
>> >> >> >> >> >> >through
>> >> >> >> >> >> >the
>> >> >> >> >> >> >desktop.
>> >> >> >> >> >> >However,
>> >> >> >> >> >> >when
>> >> >> >> >> >> >try
>> >> >> >> >> >> >start-run-"cmd"
>> >> >> >> >> >> >or
>> >> >> >> >> >> >drive
>> >> >> >> >> >> >mapping
>> >> >> >> >> >> >get error:
>> >> >> >> >> >> >permission
>> >> >> >> >> >> >to
>> >> >> >> >> >> >use
>> >> >> >> >> >> >this
>> >> >> >> >> >> >server
>> >> >> >> >> >> >to
>> >> >> >> >> >> >find
>> >> >> >> >> >> >out
>> >> >> >> >> >> >if you
>> >> >> >> >> >> >not
>> >> >> >> >> >> >been
>> >> >> >> >> >> >granted
>> >> >> >> >> >> >the
>> >> >> >> >> >> >account
>> >> >> >> >> >> >has
>> >> >> >> >> >> >now
>> >> >> >> >> >> >been
>> >> >> >> >> >> >This
>> >> >> >> >> >> >still
>> >> >> >> >> >> >hasn't
>> >> >> >> >> >> >registry
>> >> >> >> >> >> >keys
>> >> >> >> >> >> >are
>> >> >> >> >> >> >machines.
>> >> >> >> >> >> >before
>> >> >> >> >> >> >the
>> >> >> >> >> >> >hard
>> >> >> >> >> >> >Many thanks.
>> >> >> >> >> >> Clive,
>> >> >> >> >> >> (Control
>> >> >> >> >> >> Panel -
>> >> >> >> >> >> Folder
>> >> >> >> >> >> disabled.
>> >> >> >> >> >> With
>> >> >> >> >> >> your
>> >> >> >> >> >> LAN, you
>> >> >> >> >> >> "net
>> >> >> >> >> >> user
>> >> >> >> >> >> guest
>> >> >> >> >> >> Panel -
>> >> >> >> >> >> Administrative
>> >> >> >> >> >> to
>> >> >> >> >> >> this
>> >> >> >> >> >> computer from
>> >> >> >> >> >> Cheers,
>> >> >> >> >> >> Chuck
>> >> >> >> >> >> bad
>> >> >> >> >> >> thing.
>> >> >> >> >> > Chuck
>> >> >> >> >> > On the laptop:
>> >> >> >> >> > clive-laptop"
>> >> >> >> >> > to
>> >> >> >> >> > error 5
>> >> >> >> >> > has
>> >> >> >> >> > occurred.
>> >> >> >> >> > Access is denied."
>> >> >> >> >> > Regards,
>> >> >> >> >> > Clive.
Steve
Thanks. Problem now solved. See my next response to Carey for full
explanation.
All the best,
Clive.
> the network bridge
> Steve
> > Carey
> > Some success!
> now
> in
> > Thanks
> > Clive.
> from
> and
> Start,
> search
> this
> the
> > > other entries.
> > > Carey
> > > > Carey
> with
> (acting
> > > > as
> > > > unique
> security
> > > > was
> was
> USB
> it.
> > > > As
> the
> on
> > > > the
> > > > could
> > > > necessary.
> > > > either
> Ipconfig
> > > > Regards,
> > > > Clive.
> changing
> > > > wireless
> seem
> > > > thoughts.
> further
> wireless
> > > >> USB
> into
> > > >> the
> connection.
> with
> > > >> the
> > > >> wireless NICs?
> Node
> > > >> open
> > > >> this key:
> > > >> NodeType
> > > >> DhcpNodeType
> changed
> > > >> to
> > > >> Carey
> > > >> > Carey
> > > >> > 194.72.9.38
> Network
> > > >> > Adapter ver.2.6
> 07:35:25
> 07:40:25
> > > >> > Regards
> > > >> > Clive.
> contents
> > > >> >> into
> > > >> >> your next post.
> > > >> >> Thanks,
> > > >> >> Carey
> > > >> >> news
> > > >> >> > Carey
> Client
> > > >> >> > for
> > > >> >> > MS
> had
> > > >> >> > checks
> > > >> >> > next
> > > >> >> > Regards,
> > > >> >> > Clive.
> for
> > > >> >> >> MS
> xp
> > > >> >> >> pc,
> > > >> >> >> do
> > > >> >> >> they
> > > >> >> >> Carey
> > > >> >> >> > Carey
> on
> > > >> >> >> > both
> > > >> >> >> > Regards,
> > > >> >> >> > Clive.
> > > >> >> >> >> Regedit (hit enter)
> > > >> >> >> >> Close and reboot.
> > > >> >> >> >> Carey
> > > >> >> >> >> >> >laptop
> > > >> >> >> >> >> >hard
> > > >> >> >> >> >> >disk
> it.
> > > >> >> >> >> >> >The
> > > >> >> >> >> >> >nework
> > > >> >> >> >> >> >was set
> > > >> >> >> >> >> >up as follows:
> > > >> >> >> >> >> >addresses
> > > >> >> >> >> >> >set).
> > > >> >> >> >> >> >addresses
> > > >> >> >> >> >> >set).
> to
> > > >> >> >> >> >> >internet
> > > >> >> >> >> >> >through
> the
> > > >> >> >> >> >> >same
> > > >> >> >> >> >> >folders
> > > >> >> >> >> >> >set
> > > >> >> >> >> >> >for sharing.
> > > >> >> >> >> >> >through
> > > >> >> >> >> >> >the
> > > >> >> >> >> >> >desktop.
> > > >> >> >> >> >> >However,
> > > >> >> >> >> >> >when
> > > >> >> >> >> >> >try
> start-run-"cmd"
> > > >> >> >> >> >> >or
> > > >> >> >> >> >> >drive
> > > >> >> >> >> >> >mapping
> > > >> >> >> >> >> >get error:
> > > >> >> >> >> >> >permission
> > > >> >> >> >> >> >to
> > > >> >> >> >> >> >use
> > > >> >> >> >> >> >this
> server
> > > >> >> >> >> >> >to
> > > >> >> >> >> >> >find
> > > >> >> >> >> >> >out
> > > >> >> >> >> >> >if you
> not
> > > >> >> >> >> >> >been
> > > >> >> >> >> >> >granted
> > > >> >> >> >> >> >the
> > > >> >> >> >> >> >account
> > > >> >> >> >> >> >has
> > > >> >> >> >> >> >now
> > > >> >> >> >> >> >been
> > > >> >> >> >> >> >This
> > > >> >> >> >> >> >still
> > > >> >> >> >> >> >hasn't
> > > >> >> >> >> >> >registry
> > > >> >> >> >> >> >keys
> > > >> >> >> >> >> >are
> > > >> >> >> >> >> >machines.
> > > >> >> >> >> >> >before
> > > >> >> >> >> >> >the
> > > >> >> >> >> >> >hard
> > > >> >> >> >> >> >Many thanks.
> > > >> >> >> >> >> Clive,
> (Control
> > > >> >> >> >> >> Panel -
> > > >> >> >> >> >> Folder
> disabled.
> > > >> >> >> >> >> With
> > > >> >> >> >> >> your
> > > >> >> >> >> >> LAN, you
> > > >> >> >> >> >> "net
> > > >> >> >> >> >> user
> > > >> >> >> >> >> guest
> > > >> >> >> >> >> Panel -
> > > >> >> >> >> >> Administrative
> to
> > > >> >> >> >> >> this
> > > >> >> >> >> >> computer from
> > > >> >> >> >> >> Cheers,
> > > >> >> >> >> >> Chuck
> bad
> > > >> >> >> >> >> thing.
> > > >> >> >> >> > Chuck
> > > >> >> >> >> > On the laptop:
> > > >> >> >> >> > clive-laptop"
> > > >> >> >> >> > to
> error 5
> > > >> >> >> >> > has
> > > >> >> >> >> > occurred.
> > > >> >> >> >> > Access is denied."
> > > >> >> >> >> > Regards,
> > > >> >> >> >> > Clive.
Carey
WE HAVE A RESULT!!!!
I cannot thank you enough for your help. I went looking on the site
www/michna.com/kb/wxnet.htm that you referenced in your last reply and it
pointed me to the "Truobleshooting ICS on Microsoft Windows XP" document from
Microsoft. Then both you and Steve asked me questions about the router and
BINGO!
Here's the final piece of the solution.....
Set the IP address of the laptop to 192.168.0.1 (the network wizard set it
to this but I had changed it to 1.92.168.1.100 to be in the same range as the
router).
Set the IP address of the router to 192.168.0.254 (from 192.168.1.1)
Disable DHCP on the router.
Reset allowable IP range on McAfee firewall on both PCs.
Laptop now acts as ICS host computer. Desktop picks up IP address from
laptop, and not the router.
I now have no idea how my original set up ever worked. Perhaps I hadn't set
the laptop as an ICS host, but the desktop still managed to find the internet
connection somehow...
Thanks again for your help. I am indebted to you (and my kids can now get
back to instant messaging their friends!).
All the best,
Clive.
> Carey
> > Carey
> > Some success!
> > now
> > in
> > Thanks
> > Clive.
> >> and
> >> search
> >> this
> >> other entries.
> >> Carey
> >> > Carey
> >> > with
> >> > (acting
> >> > as
> >> > unique
> >> > security
> >> > was
> >> > was
> >> > USB
> >> > it.
> >> > As
> >> > the
> >> > the
> >> > could
> >> > necessary.
> >> > either
> >> > Ipconfig
> >> > Regards,
> >> > Clive.
> >> > changing
> >> > wireless
> >> > thoughts.
> >> >> further
> >> >> wireless
> >> >> USB
> >> >> the
> >> >> connection.
> >> >> the
> >> >> wireless NICs?
> >> >> Node
> >> >> open
> >> >> this key:
> >> >> NodeType
> >> >> DhcpNodeType
> >> >> changed
> >> >> to
> >> >> Carey
> >> >> > Carey
> >> >> > 194.72.9.38
> >> >> > Network
> >> >> > Adapter ver.2.6
> >> >> > Regards
> >> >> > Clive.
> >> >> >> contents
> >> >> >> into
> >> >> >> your next post.
> >> >> >> Thanks,
> >> >> >> Carey
> >> >> >> news
> >> >> >> > Carey
> >> >> >> > Client
> >> >> >> > for
> >> >> >> > MS
> >> >> >> > checks
> >> >> >> > next
> >> >> >> > Regards,
> >> >> >> > Clive.
> >> >> >> >> for
> >> >> >> >> MS
> >> >> >> >> pc,
> >> >> >> >> do
> >> >> >> >> they
> >> >> >> >> Carey
> >> >> >> >> > Carey
> >> >> >> >> > on
> >> >> >> >> > both
> >> >> >> >> > Regards,
> >> >> >> >> > Clive.
> >> >> >> >> >> Regedit (hit enter)
> >> >> >> >> >> Close and reboot.
> >> >> >> >> >> Carey
> >> >> >> >> >> >> >laptop
> >> >> >> >> >> >> >hard
> >> >> >> >> >> >> >disk
> >> >> >> >> >> >> >it.
> >> >> >> >> >> >> >The
> >> >> >> >> >> >> >nework
> >> >> >> >> >> >> >was set
> >> >> >> >> >> >> >up as follows:
> >> >> >> >> >> >> >addresses
> >> >> >> >> >> >> >set).
> >> >> >> >> >> >> >addresses
> >> >> >> >> >> >> >set).
> >> >> >> >> >> >> >internet
> >> >> >> >> >> >> >through
> >> >> >> >> >> >> >the
> >> >> >> >> >> >> >same
> >> >> >> >> >> >> >folders
> >> >> >> >> >> >> >set
> >> >> >> >> >> >> >for sharing.
> >> >> >> >> >> >> >through
> >> >> >> >> >> >> >the
> >> >> >> >> >> >> >desktop.
> >> >> >> >> >> >> >However,
> >> >> >> >> >> >> >when
> >> >> >> >> >> >> >try
> >> >> >> >> >> >> >start-run-"cmd"
> >> >> >> >> >> >> >or
> >> >> >> >> >> >> >drive
> >> >> >> >> >> >> >mapping
> >> >> >> >> >> >> >get error:
> >> >> >> >> >> >> >permission
> >> >> >> >> >> >> >to
> >> >> >> >> >> >> >use
> >> >> >> >> >> >> >this
> >> >> >> >> >> >> >server
> >> >> >> >> >> >> >to
> >> >> >> >> >> >> >find
> >> >> >> >> >> >> >out
> >> >> >> >> >> >> >if you
> >> >> >> >> >> >> >not
> >> >> >> >> >> >> >been
> >> >> >> >> >> >> >granted
> >> >> >> >> >> >> >the
> >> >> >> >> >> >> >account
> >> >> >> >> >> >> >has
> >> >> >> >> >> >> >now
> >> >> >> >> >> >> >been
> >> >> >> >> >> >> >This
> >> >> >> >> >> >> >still
> >> >> >> >> >> >> >hasn't
> >> >> >> >> >> >> >registry
> >> >> >> >> >> >> >keys
> >> >> >> >> >> >> >are
> >> >> >> >> >> >> >machines.
> >> >> >> >> >> >> >before
> >> >> >> >> >> >> >the
> >> >> >> >> >> >> >hard
> >> >> >> >> >> >> >Many thanks.
> >> >> >> >> >> >> Clive,
> >> >> >> >> >> >> (Control
> >> >> >> >> >> >> Panel -
> >> >> >> >> >> >> Folder
> >> >> >> >> >> >> disabled.
> >> >> >> >> >> >> With
> >> >> >> >> >> >> your
> >> >> >> >> >> >> LAN, you
> >> >> >> >> >> >> "net
> >> >> >> >> >> >> user
> >> >> >> >> >> >> guest
> >> >> >> >> >> >> Panel -
> >> >> >> >> >> >> Administrative
> >> >> >> >> >> >> to
> >> >> >> >> >> >> this
> >> >> >> >> >> >> computer from
> >> >> >> >> >> >> Cheers,
> >> >> >> >> >> >> Chuck
> >> >> >> >> >> >> bad
> >> >> >> >> >> >> thing.
> >> >> >> >> >> > Chuck
> >> >> >> >> >> > On the laptop:
> >> >> >> >> >> > clive-laptop"
> >> >> >> >> >> > to
> >> >> >> >> >> > error 5
> >> >> >> >> >> > has
> >> >> >> >> >> > occurred.
> >> >> >> >> >> > Access is denied."
> >> >> >> >> >> > Regards,
> >> >> >> >> >> > Clive.
My pleasure! Please sign my guestbook at www.careyholzman.com
Thanks!
Carey
news:AE57732F-4CEA-41DD-944C-A083AFE39D2F@microsoft.com...
> Carey
> from
> and
> BINGO!
> the
> router).
> set
> internet
> All the best,
> Clive.
>> Carey
>> > Carey
>> > Some success!
>> > "Access
>> > now
>> > the
>> > computer
>> > I
>> > for
>> > checked
>> > in
>> > (so I
>> > Thanks
>> > Clive.
>> >> from
>> >> Performance
>> >> and
>> >> Start,
>> >> search
>> >> Some
>> >> account
>> >> message.
>> >> access
>> >> this
>> >> the
>> >> the
>> >> other entries.
>> >> Carey
>> >> > Carey
>> >> > desktop
>> >> > with
>> >> > (acting
>> >> > as
>> >> > a
>> >> > unique
>> >> > security
>> >> > was
>> >> > I
>> >> > was
>> >> > a
>> >> > USB
>> >> > it.
>> >> > As
>> >> > so
>> >> > the
>> >> > on
>> >> > the
>> >> > I
>> >> > could
>> >> > necessary.
>> >> > on
>> >> > either
>> >> > Ipconfig
>> >> > Regards,
>> >> > Clive.
>> >> > changing
>> >> > wireless
>> >> > seem
>> >> > thoughts.
>> >> >> further
>> >> >> wireless
>> >> >> USB
>> >> >> into
>> >> >> the
>> >> >> connection.
>> >> >> with
>> >> >> the
>> >> >> wireless NICs?
>> >> >> your
>> >> >> Node
>> >> >> editor,
>> >> >> open
>> >> >> this key:
>> >> >> NodeType
>> >> >> DhcpNodeType
>> >> >> changed
>> >> >> to
>> >> >> Carey
>> >> >> > Carey
>> >> >> > Interface
>> >> >> > 194.72.9.38
>> >> >> > Network
>> >> >> > Adapter ver.2.6
>> >> >> > 07:35:25
>> >> >> > 07:40:25
>> >> >> > Regards
>> >> >> > Clive.
>> >> >> >> contents
>> >> >> >> into
>> >> >> >> your next post.
>> >> >> >> Thanks,
>> >> >> >> Carey
>> >> >> >> news
>> >> >> >> > Carey
>> >> >> >> > Client
>> >> >> >> > for
>> >> >> >> > MS
>> >> >> >> > had
>> >> >> >> > checks
>> >> >> >> > next
>> >> >> >> > Regards,
>> >> >> >> > Clive.
>> >> >> >> >> for
>> >> >> >> >> MS
>> >> >> >> >> xp
>> >> >> >> >> pc,
>> >> >> >> >> do
>> >> >> >> >> they
>> >> >> >> >> Carey
>> >> >> >> >> > Carey
>> >> >> >> >> > 0
>> >> >> >> >> > on
>> >> >> >> >> > both
>> >> >> >> >> > Regards,
>> >> >> >> >> > Clive.
>> >> >> >> >> >> Regedit (hit enter)
>> >> >> >> >> >> Close and reboot.
>> >> >> >> >> >> Carey
>> >> >> >> >> >> >> >the
>> >> >> >> >> >> >> >laptop
>> >> >> >> >> >> >> >hard
>> >> >> >> >> >> >> >disk
>> >> >> >> >> >> >> >it.
>> >> >> >> >> >> >> >The
>> >> >> >> >> >> >> >nework
>> >> >> >> >> >> >> >was set
>> >> >> >> >> >> >> >up as follows:
>> >> >> >> >> >> >> >addresses
>> >> >> >> >> >> >> >set).
>> >> >> >> >> >> >> >addresses
>> >> >> >> >> >> >> >set).
>> >> >> >> >> >> >> >to
>> >> >> >> >> >> >> >internet
>> >> >> >> >> >> >> >through
>> >> >> >> >> >> >> >the
>> >> >> >> >> >> >> >same
>> >> >> >> >> >> >> >folders
>> >> >> >> >> >> >> >set
>> >> >> >> >> >> >> >for sharing.
>> >> >> >> >> >> >> >through
>> >> >> >> >> >> >> >the
>> >> >> >> >> >> >> >desktop.
>> >> >> >> >> >> >> >computers'.
>> >> >> >> >> >> >> >However,
>> >> >> >> >> >> >> >when
>> >> >> >> >> >> >> >try
>> >> >> >> >> >> >> >start-run-"cmd"
>> >> >> >> >> >> >> >or
>> >> >> >> >> >> >> >drive
>> >> >> >> >> >> >> >mapping
>> >> >> >> >> >> >> >get error:
>> >> >> >> >> >> >> >permission
>> >> >> >> >> >> >> >to
>> >> >> >> >> >> >> >use
>> >> >> >> >> >> >> >this
>> >> >> >> >> >> >> >server
>> >> >> >> >> >> >> >to
>> >> >> >> >> >> >> >find
>> >> >> >> >> >> >> >out
>> >> >> >> >> >> >> >if you
>> >> >> >> >> >> >> >not
>> >> >> >> >> >> >> >been
>> >> >> >> >> >> >> >granted
>> >> >> >> >> >> >> >the
>> >> >> >> >> >> >> >account
>> >> >> >> >> >> >> >has
>> >> >> >> >> >> >> >now
>> >> >> >> >> >> >> >been
>> >> >> >> >> >> >> >originally).
>> >> >> >> >> >> >> >This
>> >> >> >> >> >> >> >still
>> >> >> >> >> >> >> >hasn't
>> >> >> >> >> >> >> >registry
>> >> >> >> >> >> >> >keys
>> >> >> >> >> >> >> >are
>> >> >> >> >> >> >> >machines.
>> >> >> >> >> >> >> >worked
>> >> >> >> >> >> >> >before
>> >> >> >> >> >> >> >the
>> >> >> >> >> >> >> >hard
>> >> >> >> >> >> >> >Many thanks.
>> >> >> >> >> >> >> Clive,
>> >> >> >> >> >> >> (Control
>> >> >> >> >> >> >> Panel -
>> >> >> >> >> >> >> Folder
>> >> >> >> >> >> >> disabled.
>> >> >> >> >> >> >> With
>> >> >> >> >> >> >> your
>> >> >> >> >> >> >> LAN, you
>> >> >> >> >> >> >> type
>> >> >> >> >> >> >> "net
>> >> >> >> >> >> >> user
>> >> >> >> >> >> >> guest
>> >> >> >> >> >> >> (Control
>> >> >> >> >> >> >> Panel -
>> >> >> >> >> >> >> Administrative
>> >> >> >> >> >> >> access
>> >> >> >> >> >> >> to
>> >> >> >> >> >> >> this
>> >> >> >> >> >> >> computer from
>> >> >> >> >> >> >> Cheers,
>> >> >> >> >> >> >> Chuck
>> >> >> >> >> >> >> a
>> >> >> >> >> >> >> bad
>> >> >> >> >> >> >> thing.
>> >> >> >> >> >> > Chuck
>> >> >> >> >> >> > On the laptop:
>> >> >> >> >> >> > view
>> >> >> >> >> >> > clive-laptop"
>> >> >> >> >> >> > to
>> >> >> >> >> >> > error 5
>> >> >> >> >> >> > has
>> >> >> >> >> >> > occurred.
>> >> >> >> >> >> > Access is denied."
>> >> >> >> >> >> > Regards,
>> >> >> >> >> >> > Clive.
There are 1369 identified and unidentified users. To see the list of identified users, Click here.
