Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
A7N8X deluxe
Athlon XP-2600
1GB RAM
Installed my Westell Wirespeed DSL modem with the 3COM Ethernet jack
with no problems. It worked like a charm on the first try and teh
rest of the night. Next day, the web browser won't pull anything up.
The power had blinked once and my wife found the machine off,
re-booted.
Re-installed the ISP's software from CD (very good setup util- ran
without a hitch when I originally used it on this machine). The setup
kept saying to plug in the modem, make sure it was synch'ed, etc. It
could never finish the "detecting modem and connectivity" part of the
setup.
The modem obviously trains with the ISP, since I can see the
appropriate LED blink, then blink faster, then become solid on. (Also
I can hear the subtle tones while I am on a voice call when it is
training). Also, the Ethernet LED on the modem lights up when plugged
in; flashes when the computer sends packets. The machine seems to
have a problem receiving info from the modem.
When I run the 3COM util in WinXP pro for the NIC, the "transmit"
indication flashes appropriately, the "receive" indication never
flashes.
From a command prompt, IPCONFIG gives me an IP address then my ISP's
tech support says is not valid (starts with 169.xxx.xxx.xxx, I think).
When I type PING YAHOO.COM, it cannot find the address.
The identical situation happens when I use the Nvidea LAN port.
Interestingly, same thing when I use the USB port on the Westell DSL
modem.
Plugged the DSL modem into a neighbor's computer (same ISP, same
modem) without changing anything on their machine - worked fine.
Machine seems to work fine otherwise. Any ideas? I can only figure
that part of the motherboard is fried or some BIOS settings are
corrupted. I looked int he BIOS and the only config is to enable or
disable these LAN ports - they are enabled. Why would this happen
with the USB connection also?
A7N8X deluxe
Athlon XP-2600
1GB RAM
re-booted.
setup.
flashes.
modem.
