Wireless Problems After Installing SP2
Last response: in Wireless Networking
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
My name is Brian and I am going nuts, we have customers
with this problem. Their wirless network was working
great until they installed SP2. Now the network says
limited connection or no connection. If anyone has a fix
for this other than uninstalling SP2 please email me. I
have tired a few things and I can get it working for a
short period of time but when they reboot a few times the
problem comes back....HELP.....
More about : wireless problems installing sp2
"Brian (BK's Computing)" <bkscomputing@madriver.com> wrote in message
news:10e401c4dc07$9b5ef570$a501280a@phx.gbl...
More info please. SP2 solved most of the problems I was having. Have you
enabled Wireless Zero Configuration? What security are you using (WEP or
WPA). Frequently Authentication needs to be disabled to get notebook PCs to
connect to access points if WEP is used.
Brian, there is some monumental c**k up with SP2 and wireless. Once SP2
goes on, it seems very easy for clients not to be able to get their
DHCP addresses from the server. Don't know why just yet, but I have had
several customers woth this problem. So far, my (temporary) fix has
been to set a static IP address for the client. So far MS seems to be
keeping stum about it!!!
Ron
Ron
Brian, Any help you can pass along would be greatly appreciated. I am not
particularly computer saavy and have been stumped with getting my wireless
connection back after installing SP2. We have a laptop at home connected to
our cable modem and wireless router and my daughter has a new laptop that she
loves until now since her only access is via the wireless router. The
wireless network is detected, according to the icon on the task bar, but
won't connect. When attempting to view available networks then windows says
no networks found in range. I can't disable the windows firewall in the
Security Center as it says service was not started or was stopped. I could
go on but won't ...thanks
Related ressources
- cannot create wireless network at all after installing SP2 - Forum
- After installing SP2 I can no longet connect to wireless n.. - Forum
- Wireless connectivity lost after SP2 installation - Forum
- Problem with wireless networking after SP2 - Forum
- Blue screen after installing SP2 on xp pro - Forum
I had the same problem using WEP on two notebooks. I temporally
disabled WEP to allow connection. Several days later I decided to
give it another try. I enabled WEP again on the laptop and router and
everything worked fine. I didn't have to re-enter any keys are they
were already entered from by first attempt. I don't have a clue why
it worked the second time around - I definitely had entered the proper
key as I didn't reenter anything. Any thoughts?
Jim
Jim
"Jim Besse" <fv_robinhood.nospam@hotmail.com> wrote in message
news
pNq$tK3EHA.2540@TK2MSFTNGP09.phx.gbl...
>I had the same problem using WEP on two notebooks. I temporally disabled
>WEP to allow connection. Several days later I decided to give it another
>try. I enabled WEP again on the laptop and router and everything worked
>fine. I didn't have to re-enter any keys are they were already entered
>from by first attempt. I don't have a clue why it worked the second time
>around - I definitely had entered the proper key as I didn't reenter
Maybe you rebooted the router in the meantime? Also, I recently had a
problem wherein I had to first connect to the router using WEP before I
could connect using WPA security. So maybe merely connecting with no
security allowed you to connect with WEP. Possibly the MAC address of your
network card needs to be recognized first by the router before the security
will work? Routers do strange things.
news
pNq$tK3EHA.2540@TK2MSFTNGP09.phx.gbl...>I had the same problem using WEP on two notebooks. I temporally disabled
Brian \(BK's Computing\) wrote:
> *My name is Brian and I am going nuts, we have customers
> problem comes back....HELP..... *
I'm having this problem too. The problem seems to be renewing the IP
address from the DHCP server. I have 2 laptops which I upgraded(sic) to
SP2, 1 with a Cisco card and the other with built in Centrino wireless.
The Cisco one has no problem with SP2, but the other one keeps not
being able to connect. I find that if I reboot the machine, it will
manage to find the network and get the IP. However, if I go to standby
a few times, eventually the problem will surface again. The problem
also manifests itself when I switch from a wired network (office) to my
home wireless one. Then it will not be able to renew the IP address. I
find that in this case however, if I plug in an ethernet cable which is
also connected to my router and let the wired connection get an IP, most
of the time the wireless connection will manage to get an IP in another
minute or so. This brings me to the conclusion that this problem is a
Windows problem, and I think Microsoft should fix this with high
priority, cause it's a big pain. So much for their User Experience
program.
Gavin
gavsyl
Posted via http://www.mcse.ms
View this thread: http://www.mcse.ms/message1271708.html
program.
Gavin
gavsyl
Right-click on the adapter and choose repair. Also ensure the DHCP service
is running.
Carey
is running.
Carey
Carey Holzman wrote:
> *Right-click on the adapter and choose repair. Also ensure the DHCP
> service
> is running.
> Carey
Repair doesn't work in this case. DHCP is running cause if I reboot it
is OK, or the other computer running on the network works fine.
gavsyl
> service
> is running.
> Carey
gavsyl
What driver version is your Intel adapter? Versions prior to 1.2.0.56 may
experience issues connecting to WEP secured networks. Intel has documented
and fixed this issue in current driver releases. Please, visit the
manufacturer's website for your laptop and download an updated driver.
Our Knowledge Base article:
http://support.microsoft.com/default.aspx?scid=kb;en-us;821442
Intel's documentation with links to updated drivers for some manufacturers.
http://www.intel.com/support/network/wireless/pro2100/s...
Additionally, you may want to check for updated drivers for your Cisco
wireless adapter.
Jerry Peterson
Windows Network Services - Wireless
This posting is provided "AS IS" with no warranties, and confers no rights.
"gavsyl" <gavsyl.1gxx4b@mail.mcse.ms> wrote in message
news:gavsyl.1gxx4b@mail.mcse.ms...
> program.
> Gavin
> gavsyl
wireless adapter.
Jerry Peterson
> program.
> Gavin
> gavsyl
If there are no available networks listed in the Microsoft UI, you may have
one or more of the following issues:
1) The access point is configured to not Broadcast is SSID.
2) The wireless antenna is turned off on your laptop. Check for switches or
buttons on the case of your laptop. If there is one, toggle the position to
'on' or its equivalent.
3) You may have a third party wireless utility installed that is interfering
with the Microsoft Wireless Zero Configuration service.
4) The wireless access point may be in a bad state. Power cycle the device
and check if the network becomes available.
If you need additional help please reply to this thread.
Jerry Peterson
"Katie" <Katie@discussions.microsoft.com> wrote in message
news:3DEA38D5-1BCE-424C-AE19-50A6D9BC2DD3@microsoft.com...
> not
> to
> she
> says
> could
Jerry Peterson
> not
> to
> she
> says
> could
Make sure the Network Location Awareness service is running and try
repairing the winsock using this command for XP SP2:
go to --->start-->run type CMD than type the following : netsh winsock
reset
Carey
"gavsyl" <gavsyl.1gz2s5@mail.mcse.ms> wrote in message
news:gavsyl.1gz2s5@mail.mcse.ms...
>> service
>> is running.
>> Carey
> gavsyl
reset
Carey
>> service
>> is running.
>> Carey
> gavsyl
jerry: do you have to broadcast SSID? if so, that is a change with SP2 as my
laptop has been working perfectly fine with my wireless network. your help is
appreciated.
thanks, fm
> Jerry Peterson
> > not
> > to
> > she
> > says
> > could
appreciated.
thanks, fm
> Jerry Peterson
> > not
> > to
> > she
> > says
> > could
jerry: does SP2 require encryption for wireless? or can we still configure
wireless without encryption (i used specific mac address for security).
thanks,
fm
> Jerry Peterson
> > not
> > to
> > she
> > says
> > could
thanks,
fm
> Jerry Peterson
> > not
> > to
> > she
> > says
> > could
Greetings fmaz,
There is no good reason not to broadcast a SSID. If you are not broadcasting
the SSID, the wireless service in Windows XP won't detect the network. There
is no actual security for doing it and this really isn't new in Service Pack
2. For more details, see the following MS KB Article.
Your computer connects to an access point that broadcasts its SSID instead
of an access point that does not broadcast its SSID
http://support.microsoft.com/default.aspx?scid=kb;en-us;811427
_____________
Eric Cross
Microsoft MVP (Windows Networking)
http://mvp.support.microsoft.com
"fmaz" <fmaz@discussions.microsoft.com> wrote in message
news:BFBA54E8-CA72-4F63-8EB0-8D01A4EE398D@microsoft.com...
> my
> is
> appreciated.
> thanks, fm
>> have
>> or
>> to
>> interfering
>> device
>> Jerry Peterson
>> rights.
>> > not
>> > wireless
>> > connected
>> > to
>> > that
>> > she
>> > but
>> > says
>> > the
>> > could
Greetings fmaz,
_____________
Eric Cross
> my
> is
> appreciated.
> thanks, fm
>> have
>> or
>> to
>> interfering
>> device
>> Jerry Peterson
>> rights.
>> > not
>> > wireless
>> > connected
>> > to
>> > that
>> > she
>> > but
>> > says
>> > the
>> > could
Related ressources:
- Forumno wireless connection after SP2
- ForumWireless Network Does Not work after SP2 Upgrade
- ForumWIreless Networking after SP2 ....
- ForumProblems with network after SP2 Install
- ForumNo wireless access after SP2
- ForumXP SP2 wireless problems
- Forumlinksys wireless router and SP2 problems
- ForumWireless after SP2
- ForumNo Remote Desktop After SP2 Install
- ForumXp pro, boot failures after after install SP2 .
- ForumAnyone have problems installing software after SP2 install?
- ForumWindowXPP SP2 Wireless issues
- ForumBest wireless network card for my router?
- More resources
Read discussions in other Wireless Networking categories
