G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Back in early Feb of 04, I built a system for my sister in law as
follows:
Asus A7V600 Motherboard
Athlon XP 2800/333 (2.08 GHz)
Corsair XMS Extreme Memory Speed Series, Low Latency (Twin Pack) 184
Pin 512MB(256MBx2) DDR PC-2700 with Platinum-Silver Heat Spreader
ASUS V9520TD GeforceFX5200 128M
1 80 GB Maxtor SATA Drive, model 6Y080M0
DVD+RW PLEXTOR PX-504A-SW IDE RET
Sony 1.44 MB Floppy drive
Antec Lanboy case w/350W Power Supply
I built the machine with Windows XP Professional service pack 1a and
had no problems. The machine worked for about a month before problems
began. The first problem was that XP refused to boot pased the inital
splash screen. After some troubleshooting, I realized that the
operating system was unable to detect the hard drive. I tried
reinstalling XP Pro, and discovered that it took 20 minutes to detect
and check the hard drive. Guessing that the hard drive was going bad,
I downloaded the Maxtor PowerMax diag tool from the Maxtor website,
only to find that it does not support SATA RAID controllers on the
NVidia chipsets. I called Maxtor anyway, and got them to send me out
a replacement drive. I rebuilt the machine (again, having no
problems) and returned it to her.
Two weeks later, it is dead again. This time, however XP can see the
drive, it just won't boot from it. I was able to get it to boot into
safe mode, but could never get it to boot into normal mode without
hanging at the boot screen.
I thought that the onboard NIC may be causing problems since its
driver is not loaded in safe mode, and the machine would hang if
booted in Safe Mode with Networking. I tried disabling the NIC in the
BIOS and in the OS, but could not get the machine to boot. After a
few tries, it refused to boot in any mode, safe mode or normal mode.
I then rebuilt the machine again, using Windows 2000 Professional,
service pack 4. After the OS installation, the machine blue-screened
claiming that the software key of the registry was corrupt. I rebuilt
the machine again, using Win2k. This time the machine ran for about
two weeks, before blue screening again, same error--software key of
the registry is corrupt.
I tried updating the motherboard BIOS to 1006, and tried updating the
drivers for the SATA RAID, but to no avail.
I've been building PCs for 10 years and have been using ASUS
motherboards for much of that time. I've never had problems such as
these. I don't know whether the problem is another bad drive, or a
motherboard incompatibility or something else. I cannot run the
PowerMax diags on the drive because I don't have another machine with
a supported SATA controller.
Has anyone experienced problems like this before with this board, or
does anyone have any suggestions or what I might try next to fix this
problem ?
Thanks,
follows:
problem ?
Thanks,
