Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi there,
Not sure if this issue is connected to the Audigy but since doing a format
and clean install of XP and then installing the Audigy there seems to be a
problem with the Local Area Connection Status icon not appearing in the task
bar unless I go into Control Panel and double clicking on Network
Connections then the icon appears.
Anyone else experienced this problem or know of a possible solution?
Secondly I have the Audigy in PCI 4 is that the right slot or should it be
in slot 3?
P4 3.2 800fsb
1 gig Corsair 3200 RAM
3 x SATA drives in now raid configuration
Connect ATI AIW 9800 pro latest drivers
Intel modem slot 5
Slots 3,2,1 empty
Many thanks for any help or pointers, Tim.
Hi there,
in slot 3?
P4 3.2 800fsb
Intel modem slot 5
Slots 3,2,1 empty
