Archived from groups: microsoft.public.windows.networking.wireless (More info?)
I have recently established a Wireless connection between my desktop and
laptop through an access point / router.
My destop is running Windows XP with SP2 whilst my laptop is using Windows
2000.
I have been unable to create a home network between the two to take
advantage of the wireless connection and my broadband internet connection.
Windows XP network setup wizard says it is unable to create a set up disk for
systems operating windows 2000.
Is there any way of getting around this and so create the home network?
Greetings Andrew,
The Network Setup Wizard is incompatible with Windows 2000. It will only
work on Windows 98, ME, and XP. There's no problem though. It is never
necessary to use the Network Setup Wizard even if it tells you to do so. You
should be able to doing everything without doing much. Setting the workgroup
name on the 2000 machine to MSHOME will make networking a little easier.
Try testing the network and shares this way. Click Start, Run, and type one
of the following commands in the Open box and then press ENTER.
"Andrew Taylor" <AndrewTaylor@discussions.microsoft.com> wrote in message
news:ED9D427A-4656-414B-9985-DF93AC71CB09@microsoft.com...
> 2000.
> for
> and laptop through an access point / router.
> Windows 2000.
> connection. Windows XP network setup wizard says it is unable to
> create a set up disk for systems operating windows 2000.
> network?
IIRC, you can't run the wizard on Win2k. Do you know if the wireless on
the laptop works? Can it see the access point? Since we don't know what
you've done or your hardware, it's hard to be specific. However, let's
assume that you know your wireless hardware on the laptop works (you've
tried it at a friends, Starbucks, etc.).
Go to your router's configuration settings. Most routers are configured
in your browser by entering http://192.168.x.x and then the default
user/password - this depends on the brand of router. Refer to the
router manual.
Go to the wireless and make the SSID a name that is memorable to you;
i.e., "taylor" or the like. Set a WEP key and write it down. Some
routers let you use a text passphrase to create the key. Go ahead, but
the key - numbers - is what you write down. You will not use the
passphrase on the laptop.
Now go to the laptop and configure its wireless to match the SSID and
WEP key to that on the router. How you configure the laptop's wireless
depends on what the hardware is. There will be some sort of wireless
connection manager.
If you need more help, then please post back to this thread with more
information about your hardware and what you've already tried to do.
Lets see I am trying to remember how I did this when I used the 2 OS.
If I remember right I just ran the Network wizard seperately on each machine
without making any disk.
I also enabled sharing by right clicking the drives.I also mapped the networked
drives under "my network places"
peter
> 2000.
Dear Malke
Thank you for your response. I appreciate receiving your reply.
I am running the Draytek Vigor 2600G wireless router on the desktop and the
Vigor 540 wireless cardbus adapter on the laptop. I can confirm the laptop
WLAN manager utility program has made contact with the router. SSID, WEP and
channels all match. I have checked the desktop router configerator on the
web to see if it has found the laptop but not totally sure how to do this!
As the laptop has clearly located the desktop then Iis it fair to assume the
desktop has found the laptop?!
I have also managed to set up a home network on the desktop called 'Mshome'
which can be seen in the My Network Places / workgroup screen. Equally the
same network 'Mshome' appears within the Entire Network / Microsoft Windows
Network screen on the laptop.
However the problem now is that when I go into the Mshome network on the
laptop and receive the following error:
\\Taylor is not accessible -- (Taylor being the desktop computer name)
There are currently no logon servers available to service the logon request
Any additional thoughts?
Many thanks
Andrew
> > Windows 2000.
> > network?
> router manual.
> connection manager.
> Malke
> MS MVP - Windows Shell/User
> Elephant Boy Computers
> www.elephantboycomputers.com > "Don't Panic!"
> Dear Malke
> and the
> laptop
> WEP and
> the web to see if it has found the laptop but not totally sure how to
> do this! As the laptop has clearly located the desktop then Iis it
> fair to assume the desktop has found the laptop?!
> 'Mshome'
> Equally the same network 'Mshome' appears within the Entire Network /
> Microsoft Windows Network screen on the laptop.
> the laptop and receive the following error:
> name) There are currently no logon servers available to service the
> logon request
1. Make identical user accounts/passwords on both machines.
2. Make sure the lan IP range is put in any firewall settings as
trusted.
3. I assume the laptop is your home laptop and isn't normally connecting
to a domain - at work, perhaps?
4. Make sure your connection is set to get an IP address (from the
router) automatically. I'm not familiar with that particular router,
but I am assuming it is providing DHCP.
Dear Malke
Thank you for your reply.
I can confirm the wireless network is working. The SSID, WEP and channels
between my desktop and laptop all match. The connection status on the WLAN
utility program on the laptop indicates their is a connection. I did try to
check the destop web router configerator to ensure a similar connection but
was not sure exactly how to do this! I am using a Draytek Vigor 2600G router
on the destop and a Vigor 540 cardbus on the laptop.
I have also managed to create a network worgroup entitled 'Mshome' on the
desktop and this has been identified on the laptop under My Network Places.
The further problem I am having is that when I try and open the network on
the laptop I receive the following error message:
\\Taylor is not accessible -- (taylor is the name of the desktop!)
There are currently no logon servers available to service the logon request.
Do you know how to resolve this problem?
Many thanks
Andrew
> > Windows 2000.
> > network?
> router manual.
> connection manager.
> Malke
Apologies for the previous response which kind of just repeats what was
already said. New to this message board technique but have to say it is very
helpful.
I suspect my problem is that my laptop is used at work from time to time.
A few further questions if I may:
1. Not sure what you mean by identical user names / passwords? I do not
have any such control attached to the network connection.
2. How do I find the IP address of the laptop?
3. I have just checked the system folder on the laptop and it does have a
different computer name and is pointing to a domain. I do have the option to
change this to workgroup.
4. The web router certainly refers to a DHCP server setting. Not sure how
to change settings on the laptop.
Many thanks
Andrew
> > Dear Malke
> > and the
> > laptop
> > WEP and
> > 'Mshome'
> > logon request
> trusted.
> Malke
> was
> is very helpful.
> time.
> not have any such control attached to the network connection.
> have a
> option to change this to workgroup.
> sure how to change settings on the laptop.
I'm really hesitant to suggest you change anything on the laptop since
it connects to a domain. It *should* be all right if you log in
locally, but you would do better to ask your systems administrator at
work for exact instructions to do what you want. In the meantime, here
is a network troubleshooter and some other links to check.
