Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have recently purchased a lite-on 411s dvd +/- r/rw
drive. I am able to burn cd-r's no prob, but for some
reason it appears that xp doesn't recognize it as a dvd
player/burner? i can view a dvd in the drive but however
i cant use the "dvd-rom" only functions of the dvd
itself. i cant figure out how to burn dvd's either. i
have tried using a couple different programs to burn but
none work. i cant even use windows to burn, it won't
recognize any media. i've tried some memorex + r media &
some fuji - r media...every time every disc comes up as
saying no disc in drive or disc is full??? can you
help? thanks! ben
Sponsored Links
Try using your Burner in another machine and see if you
get the same problem...
If not then try a reinstall of windows and then see if the
problem still occurs...
HTH
James
>-----Original Message-----
>help? thanks! ben
Reply to James
Hi, I also had a problem I could not solve on my own.
My cd writer was not recognized by XP home edition.
I posted my problem on Windows XP Hardware newsgroup, got one reply, but I didn't know
how to implement the reply. In desperation I poked around my computer
until I stumbled on Help and Support. I asked for support and in less then 24 hours
they e-mailed a detailed step-by-step procedure, which solved my problem.
Since my knowledge of computers is marginal, at best, it was important for me that the
procedure was very detailed and did not assume that I know anything about computers.
If you would like to get support to solve your problem, left click on:
Start>Control Panel>Help and Support (on left panel)>>Get support (on right panel)>Get help from (on left panel)>>Ask support professional for help (on right panel), then answer a series of questions.
All the best, Adam
Reply to Anonymous
thanks for the help with the help & support, but it didnt
work for me. for some reason it told me that they wont
accept my product id, because it was a preloaded version
of xp that came w/ my pc purchase??? is there any chance
you have the documentation that was given to you to fix
your problem? thanks...
as for the response to the second issue...i dont have
another pc to try to drive in unless there is a way to
use an internal pc drive in a laptop (and the way being
easy) i am kinda at a loss because as seen above i dont
have a xp disc & thus i cant reinstall it. and my pc
manufacturer states that they can not give me a copy of
xp to reinstall xp, my only option would be to do a full
restore...and without being able to backup files to my
dvd's it would day weeks to do it to cd-rw and not to
mention the hassle...is there any recourse???
thanks so much...again...ben
Reply to Anonymous
Just a thought - and maybe a bit of straw-clutching - but is it necessary to
turn off Write enable in Windows XP if you're using different software, e.g.
Nero 6?
Peter
"ben bob" <benbob12345678@yahoo.com> wrote in message
news:cd9f01c43979$451979a0$a401280a@phx.gbl...
> help? thanks! ben
Reply to peter
I have the same problem. My Sony DRU-500a DVD writer worked just fine under Windows 2000 Pro. Under Win XP Pro,it is recognized as a DVD writer, but it will only recognize CD media. Reloading the operating system does not help.
Reply to Jim
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > problems burning dvd's
There are 1187 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
