Archived from groups: microsoft.public.windowsxp.hardware (More info?)
XP Home O/S. The programs I run say the sound card is
either not there or it is in use by something else, and I
know it is not because nothing is running I know about
that would be using it. I was told it is due to a bad xp
upgrade. I have no clue if it is that and if so what next
or if there is another issue I am missing. The systems
sound card worked before I installed a new one. The new
card is good, we know this from using it in another
system. Help??!!
If you install a separate soundcard you MUST disable the onboard sound in
the BIOS.
And try to install the separate soundcard in the PCI slot FURTHEST away from
the AGP slot.
Cari
MS-MVP Windows Technologies - Printing/Imaging/Hardware
www.coribright.com
"Jeff" <anonymous@discussions.microsoft.com> wrote in message
newsc0301c43b63$b23c3db0$a601280a@phx.gbl...
> system. Help??!!
Cari,
Thanks for the info, but I am not sure how to do what you
said. Could you explain it or is this a major technical
thing?
>-----Original Message-----
onboard sound in
>the BIOS.
FURTHEST away from
>the AGP slot.
>Cari
>www.coribright.com
message
I
xp
next
>> system. Help??!!
