News
Asustek Launches Power Efficient Server Board
Published on December 21, 2007
Asustek Computer has announced the DSEB-D16 series server board, a 45nm Intel Xeon 5400/5200 processor ready platform, which the company claims is capable of 90%+ power efficiency. Read more
External SATA Devices To Drop Power Cables
Published on January 14, 2008
The Serial ATA International Organization (SATA-IO) has announced that it is working on a new specification that will provide power to external SATA (eSATA) devices without the need for a separate power connection. Read more
Thermaltake launches Purepower RX series power supplies with 140 mm fan
Published on January 04, 2007
Thermaltake Technology announced the launched of its new line of Purepower RX series ultra-low noise power supplies incorporating the ultra-silent 140 mm fan found on Thermaltake's high-end Toughpower Series power supplies. Read more
STMicroelectronics introduces auto-shutdown LED driver
Published on February 26, 2007
STMicroelectronics (ST) has introduced what it claims is the first LED driver to include auto-power-saving features. Read more
Latest Reviews & Articles
Best Video Cards For The Money: Nov '08
Published on November 10, 2008
Detailed graphics card specifications and reviews are great—that is, if you have the time to do the research. At the end of the day, though, what a gamer needs is the best graphics card within a certain budget, and that’s what we’re going to show you. Read more
Power Supply Roundup: Part II
Published on November 07, 2008
In Part I of our power supply roundup, we went through five mainstream PSUs rated at up to 700 W. Round two sees us tackle another seven mid-range units in an effort to determine which power supply deserves your attention. Read more
Roundup: The Best Overclocking Software
Published on November 06, 2008
Interested in overclocking but not quite sure where to start? We round up some of our favorite software utilities for tweaking processors, memory, graphics, and chipsets. Read more
Tom's Holiday Buyer's Guide 2008, Part 1
Published on November 05, 2008
Welcome to the first installment in our six-part Tom's Holiday Buyer's Guide. In Part 1, two beautiful models help showcase some of our favorite no-hassle hardware gifts for 2008. Read more
  Tom's Hardware Forums » Motherboards & Memory » Asus » A7V8X-X brief power then off
Word :   Username :
Bottom
Author
 Thread : A7V8X-X brief power then off
More Information
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Old system was a ECS K7S5A. I grew weary of the never ending quirks but
nominally the box was working.
Two Micron 512MB DDR2700 CL 2.5 memory sticks, newish, but tested with
the old board.
Everything else is the same:
Athlon 1500XP
Cheapie case and power supply
Without memory:
Hit power supply switch.
Hit front panel power switch.
Power LED lights on motherboard.
Long beep, CPU fan comes on, drives get power.
Maybe 5 seconds.
Everything powers down.
Power LED still on. No response to front panel.
With memory: same as above only no beep.
Any ideas?
Photos and travelogues from Africa and Southeast Asia: http://www.exile.org
Related Product
More Information
On Mon, 21 Jun 2004 19:44:46 +0000 (UTC), Eric Edwards <ese002@news9.exile.org> wrote:
>the old board.
>Athlon 1500XP
>Without memory:
>Maybe 5 seconds.
I swapped memory, cpu, and video card into the old ECS board. They
work. Since returning the components to the A7V8X-X and reconnecting
power, things have changed though I don't really know why.
Power stays on most of the time. Occasionally, it shuts down after a
lengthy period but mostly it stays running.
If no video board, the motherboard complains ( one long, 3 short beeps).
If video present, then no complaints, but no video either. The video
board remains dormant. Monitor does not see a signal.
No disk activity as far as I can tell though they do have power.
Keyboard LEDs blink on power up.
Reset seems to cause a click from the speaker but, otherwise, no effect.
Profile: stranger
More Information
i have/had similar issues.
what do you have for a video card?
what bios is on the a7 board?
my a7v8x-x had memory issues, would not see anything more than 512.
now it is dead, everything powers up but no post, no beeps, no video signal.
good luck
john
btw i also moved from an ecs k7s5a board to the asus board.
ever since then my ecs board has worked great, go figure.
"Eric Edwards" <ese002@news9.exile.org> wrote in message
news:slrncdeele.d2b.ese002@spica.exile.org...
> the old board.
> Athlon 1500XP
> Without memory:
> Maybe 5 seconds.
> Any ideas?
More Information
In article <slrncdes1q.rf2.ese002@spica.exile.org>, ese002
@news9.exile.org says...
What kind of video card are you using?
More Information
On Mon, 21 Jun 2004 21:28:16 -0400, Hubert Hump <hh@youmustbekidding.com> wrote:
I have two to play with:
1) Ancient but reliable 8 bit STB/Aware PCI card.
2) "generic" Savage4 AGP card.
Difficulties in getting reliable contact in the K7S5A's AGP slot
contributed to the decision to buy the A7V8X-X. Strictly speaking, I
don't know that the AGP card still works. I'm doing most of my testing
with the PC card.
The newest twist is that, using the reset switch, I can briefly get
activity out of the video card. It's too brief to actually display
anything but the monitor does pick up a signal. That's with the PCI
card.
Now, I'm getting "bad or missing video" beeps from the AGP card. Maybe
it is dead. Doesn't explain why the PCI card doesn't work though.
More Information
The manual says Award. Without video, it's hard to confirm.
What sort of simm arrangement?
I do have some concerns about the memory. It's PC2700 but the CPU only
has a 133Mhz (DDR266) front side bus. It's not an issue with the ECS
board. DDR266 if as fast as it goes. The Asus, though, could run the
memory at DDR333.
More Information
>good luck
>john
Are you using the same CPU in both? I just moved the video and cpu back
to the K7S5A (2nd time) and now it is behaving just like the ASUS!
At this point, all ideas that I see are:
1) Coincidental wiring/shorting issue.
2) I somehow killed the processor when I moved it to the ASUS last time.
3) Flakey, but not dead, power supply.
The video card is again confirmed working in the ancient 486 box from
which it came.
More Information
I had a similar problem on a system I built for someone using that
board. I swapped everything in and out several times. All components
worked fine in other boards. Turned out it is apparently very picky
with memory. The memory I had used worked fine in other machines
(different MBs), but not in that one. I ended up getting a new stick of
PC2700, Kingston or PNY I believe it was, and it was happy. Been happy
ever since (knocking on wood now!). You might check the Asus web page
and see exactly which memory it says will work with that board and try that.
>the old board.
>Athlon 1500XP
>Without memory:
>Maybe 5 seconds.
>Any ideas?
Google Ads
