Tom's Hardware > Forum > Computer Peripherals > Printers > Epson Stylus C40 Plus Print Quality
Forum Computer Peripherals : Printers - Epson Stylus C40 Plus Print Quality
Archived from groups: comp.periphs.printers (More info?)
I have an epson stylus c40 plus which is about 2 years old and
> > originally the print quality was excellent but recently their is a lot
> > of horizontal banding in the print outs. I have performed a nozzle
> > check,head cleaning check and print head allignment check and all were
> > fine. I tried to resolve this on the epson website but the support
> > was pretty poor. Has anyone got any ideas on how to resolve this?
> > thank you
> This is usually the well known and documented build up of resin residue and
> crud from paper waste (dust) and dye based ink . The very best way is to
> charge a spare empty with Windolene (greenish) window cleaner or a mild
> ammonia solution which acts as a solvent for dye based inks. You then clean
> from within the Peizo head and dissolve waste out. Print a few windy pages
> and as the ink fades you know the cleaner is getting to the parts that
> matter. Sometimes a few drops on the parking pads will accomplish this. No
> disassembly is necessary. Amongst others JetTec also do a flush cleaning
> fluid free with the latest specialist ink kits.
> Tony.
I dont fully understand what some of the jargon means. Can someone
tell me what charge, clean from within the PEIZO head, windy pages and
parking pads mean? thanks for your help.
Sponsored Links
"Peach" <leepeche@hotmail.com> wrote in message
news:d20e7d56.0404200227.6edec717@posting.google.com...
> > > of horizontal banding in the print outs. > I dont fully understand
There is no tech jargon involved - just plain old English;
Charge or fill a spare cartridge with an ammonia solution which is a solvent
for dye based inks. Printing with this refilled cartridge cleans from inside
to out which is the same as within: and within is not without but the
opposite.
Ignore the Pizza bit as that is what Epson printhead technology is called.
Printheads park on pads to seal them whilst not in use. And parking is the
same as the car type - lack of motion. So a few drops of a solvent on a
parking pads could unglue you or infuse the heads - somewhat like Sinex or
an inhalant may offer cold relief.
Then you should , could, or may be able to operate without banding or gaps
in attempted printing.
Oh and gaps are the white bits between the dark bits which you may or may
not want :-))
Blame Guttenburg or that Russian Concordski as they claim they started it.
Tony
Reply to Tony
There are 464 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
