Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I've got a ASUS P4C800-E Deluxe mobo, with 2 SATA HDD's installed. A Pioneer DVD-121 ROM drive is installed as master on the secondary IDE channel and it is the only device on the channel. On the primary IDE is a Plextor Premium CD Burner. It's also the only device on the channel. I'm running WinXP PRO SP1.
I'm not sure of the BIOS version, I know it's not the latest, I think it's 1009 or similar.
Anyway, Device Manager shows the Plextor using Ultra DMA Mode 4, while the Pioneer is using Ultra DMA Mode 2. The Pioneer is SIGNIFICANTLY slower than the Plextor, eg. ripping music.
According to http://www.pioneeraus.com.au/computer/dvd-romdrives/dvd121/index.html, it states the Interface supports:
ATA PIO Mode 4 / Multi Word DMA Mode 2 / Ultra DMA Mode 4
Device manager shows everthing is working OK. WU doesn't have any device updates, etc. There are no Firmware updates listed in the Pioneer sites that I've found. However, I've found a FW DVD region crack that states that it is built on v1.07 ... the Pioneer came with FW v1.02.
As yet I haven't tried swapping cables or similar. Is it even worth trying?
Is this normal? If not, where would the problem most likely be ... the DVD drive (firmware?) or some where else (Driver/BIOS/whatever)?
Cheers
Bazza...
Cheers
Bazza...
