Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a Radeon 9800 Pro graphics card, on a Asus P4P800-E Deluxe motherboard with a Prescott 3.2Ghz Processor. The system has a 480W power supply. everything runs fine in Windows (XP) but as soon as I tried to do anything in 3D, eg play a game or run 3D mark then the display turns to coloured vertical lines and about 10 seconds later the system restarts. I have installed Service Pack 1, updated to the latest display drivers and latest version of directx, am using the latest BIOS and the card works fine in another system. Any ideas what could be causing the problem?
Thanks in advance
Sponsored Links
Is your Radeon card actually from ATI or another brand?
Is the BIOS set to run the AGP at 4x or faster? Is the
cooling fan running on the card?
What does the device manager say about the graphic card and
what are the settings in display properties?
What screen resolution and color depth and what type of
monitor?
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Paul Singleton" <paul_singleton@yahoo.co.uk> wrote in
message
news:5107BC1D-4423-4C24-9BA8-33EE1B158CEE@microsoft.com...
| Thanks in advance
Reply to Anonymous
The card is manufactured by a company called Medion, and I've tried downloading the drivers specific to that card from there website. If I use the ATI reference drivers the card is shown as Radeon 9800 Pro in device manager, if I use the drivers from the Medion website then it shows as Medion 9800 XL. The BIOS is set to run 8x AGP which the card is. I'm currently running in 1024 x 768 with 32bit colour, but have the same problems at both higher and lower resolutions. I'm using a 17in CRT monitor and the refresh rate is 60Hz
Thanks
Reply to Anonymous
I suspect the card is defective, it should breeze through at
those settings.
It should be able to run 85Hz or faster at that modest
resolution and slow refresh rate of 60 Hz it should have no
problems.
See if you can get a real ATI brand card.
message
news:D1E5E7AF-0FD0-429A-A939-0F8499080DE9@microsoft.com...
| Thanks
Reply to Anonymous
Did you connect the 4 wire power plug to the video card ?
"Paul Singleton" <paul_singleton@yahoo.co.uk> wrote in message
> Thanks in advance
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Graphics Card Problem
There are 1238 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
