Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have a wireless mouse and when I stop moving the mouse the light on the reciving end still blinks, also the light on the mose part of it flickers sometimes when I turn it upside down to look at the light inside.
This hard somtimes to control the motion of it when I using it and trying to click on somtheing small and the mouse pointer just jumps around. What can I do to stop this.
AndreL said in news:AFBD68FF-DBF5-4D78-B918-15F5BB231DA1@microsoft.com:
> inside.
> Thxk in Adv ...
Have you pressed the sync button on the receiver and the mouse?
Have you checked that no one near you also uses a cordless mouse? I've
seen one user have problems because another user up one floor and about
50 feet away was also using a cordless mouse although, I believe, the
max distance apart is supposed to be 15 feet with a recommendation that
they be 12 feet apart.
Uninstall the vendor's mouse software, reboot to use the std ps/2 mouse
driver, configure the ps/2 driver to its defaults (no acceleration,
medium speed, no snap-to button action, no clicklock), and then
reinstall the vendor's mouse software.
Have you tried upping the sampling rater and/or buffer size (Device
Manager, properties for the mouse device)?
____________________________________________________________
*** Post replies to newsgroup. Share with others.
*** Email: domain = ".com" and append "=NEWS=" to Subject.
