Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Up until today - no probs. Went to start PC this morning
and boot sequence froze before POST. Blank screen, no
beeps. After messing for a while I found that if I left
the Keyboard connector disconnected it booted up fine. I
also found that if I left the keyboard connected and
pushed the reset button after it froze that the PC booted
up OK - if I then tried a restart the PC, shutdown OK but
would freeze during the boot process with the same
original symptoms.
Have you tried a different keyboard ? Is this a PS/2 (not
USB) keyboard ?
>-----Original Message-----
>original symptoms.
>Winxp box
>Microsoft wireless desktop pro.
The keyboard connector from the wireless receiver unit is
PS2 - I have tried a standard PS" wired Keyboard and the
PC boots with no problems.
(not
>USB) keyboard ?
morning
I
booted
but
>>original symptoms.
>>Winxp box
Hi,
I think you are using the PS/2 to USB adapter to connect the keyboard receiver.
Try connect the keyboard receiver using USB; if the symptom went away, the culprit is the adapter. It may not firmly connected to the PS/2 port or it is faulty.
Peter
----- Zaphod wrote: -----
(not
>USB) keyboard ?
morning
I
booted
but
>>original symptoms.
>>>>Winxp box
The connector for the keyboard is PS2 only. It is only
the mouse connector that is USB with a PS2 adapter.
>Hi,
>Peter
unit is
and the
PS/2
> (not
> >USB) keyboard ?
> morning
screen, no
I left
fine.
> I
and
PC
> booted
shutdown OK
> but
same
> >>original symptoms.
> >>>>Winxp box
