Help with wireless network!
Last response: in Wireless Networking
Archived from groups: microsoft.public.windows.networking.wireless (More info?)
My computer won't connect to our home wireless network. It identifies the
network and tries to connect and then says that it can't, or that the server
is denying it access. I dont know how our network is set up but we don't
have a server, just a router, please help with this problem. Would it help
if I assinged the Ip addresses to my computer manually instead of it
obtaining it automaticly? Thank you.
More about : wireless network
> the network and tries to connect and then says that it can't, or that
> the server
> don't
> help if I assinged the Ip addresses to my computer manually instead of
> it
You apparently have an encryption key set on the router. You need to
enter this key into the computer's wireless network settings. You can
see the key by using the router's configuration tool, accessed through
your browser.
Malke
MS MVP - Windows Shell/User
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
Sorry, could not post a new thread, and so am piggy backing with a similar
problem. I am travelling a lot and my wireless card was connecting
automatically and fine to any network in range in all the hotels and coffee
shops I was going to. Now all of a sudden it says: "no wireless networks were
found in range. Make sure the wireless switch on your computer is on." I try
to refresh the network list and get the same thing even when I know I'm in
range of a network. I do not know how to switch my wireless switch on, I have
a dell inspiron 8600 running Windows XP, and I don't know how I could have
switched it off. Someone checked my settings and said that it all looked okay
to them. Can anyone give me any advice?
> > the server
> > don't
> > it
> your browser.
> Malke
> "Don't Panic!"
Hi
Wireless Client (like a Laptop with Wireless Card) and the Wireless source
(like an Access Point, or a Cable/DSL Router) have to be set in a similar
way in order to connect.
Wireless - Basic Configuration: http://www.ezlan.net/Wireless_Config.html
Wireless - Basic Security: http://www.ezlan.net/Wireless_Security.html
To enjoy free public Wireless networks you can use a second setting that
allows the Wireless to automatically connect to any Free available Network.
When tying public Wireless your millage might vary since there might not be
a free open Wireless Network available.
Windows XP can be natively configured to two different setting, if you need
more than two there are third party applications that might help.
Jack (MVP-Networking).
"Smedley" <Smedley@discussions.microsoft.com> wrote in message
news:ECF551AB-8186-4112-BAA3-C723218D01CE@microsoft.com...
server
help
"Jack" wrote:
> Hi
> server
> help
Smedley.
I had the same problem and resolved it by calling the Link Sys Tech line.
They had me connect the lap top to the router by ca ble then they walked me
through the set up page at 192.168.1.1 made sure everything was OK there then
had me log on to the web page and logged on to their automatic set up site
and the web page did the whole thing from there.
They also made sure my drivers were up to date, which they were not since
upgrading to XP, and now they link works like a charm
Geoff
"Jack" wrote:
> Hi
> server
> help
Ask the community
