Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I bought a used HP Pavilion 7955 desktop PC for $10 on eBay and the stock ASUS
P4U-LA mobo was totally fried from a lightning strike. So I bought an Intel
D845HV mobo to replace it, and the install went smooth except I cant figure out
how to connect the HP's front-panel USB connector to the D845HV mobo connection.
It's a standard 10-pin connector, but the female connection on the D845HV is
configured different than the ASUS P4U-LA mobo. Basically, I need to get the
pin codes off the P4U-LA female USB connector so I can properly mate the
front-panel male connector to the D845HV female USB mobo connection.
I have to be careful about just playing around with this connector because
putting 5V power to the wrong pin can fry my new mobo.....correct? I tried
looking up the P4U-LA technical manual on the ASUS site but no luck....it
appears it was a custom micro-ATX board for this HP system.
Please let me know where I can find the USB pin code for this mobo.
