Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi all,
I'm trying to create a network bridge so that a computer with a wireless
network card can connect to the internet through another computer with a
wireless network card and a wired card. Both computers are running WinXP
Home SP2. The catch is, that the computer that will be acting as the
bridge (the one with two cards, wired and wireless) connects through a
router. So, to summarise, here's my setup:
Internet <--> ADSL modem <--> router <--> computer with wired and
wireless cards <-//-> computer in another room with wireless card
So far I can't get the computer in the other room to be able to connect
through to the Internet, and I've tried a buttload of different things
and permutations. Is this even possible? Is it like a two NATs don't
make a connection sort of deal?
TIA,
Ari
spammage trappage: replace fishies_ with yahoo
I'm going to die rather sooner than I'd like. I tried to protect my
neighbours from crime, and became the victim of it. To jump to the end
of the story, as a result of this I need a bone marrow transplant. Many
people around the world are waiting for a marrow transplant, too. Please
volunteer to be a marrow donor:
http://www.abmdr.org.au/ http://www.marrow.org/
spodosaurus wrote:
> Hi all,
> TIA,
> Ari
Update:
I'm still trying to figure this out, but I appear to be one step closer.
Here's what I did after deleting the bridge:
1. turned on the DHCP server on my router
2. set the wireless card on the bridge computer to ad-hoc mode using its
manufacturer's software
3. re-created the bridge
4. changed the computer in the back room's wireless settings to receive
an IP automatically
It appears now that the computer in the back IS getting an IP from the
router! It's the second IP in the DHCP list, right after the one
assigned to the bridge computer. Unfortunately it STILL cannot connect
to the Internet.
Cheers,
Ari
spodosaurus wrote:
> spodosaurus wrote:
>> Hi all,
>> wireless network card can connect to the internet through another
>> computer with a wireless network card and a wired card. Both computers
>> are running WinXP Home SP2. The catch is, that the computer that will
>> be acting as the bridge (the one with two cards, wired and wireless)
>> connects through a router. So, to summarise, here's my setup:
>> connect through to the Internet, and I've tried a buttload of
>> different things and permutations. Is this even possible? Is it like a
>> two NATs don't make a connection sort of deal?
>> TIA,
>> Ari
> Update:
> an IP automatically
> to the Internet.
> Cheers,
> Ari
Tracert fails at the first hop, by the way. So I've got the router
sending the IP to the remote computer through the bridge, but that's it.
Also, there's no firewall turned on for either the remote computer or
the bridge.
Ari
spodosaurus wrote:
> spodosaurus wrote:
>> spodosaurus wrote:
>>> Hi all,
>>> computers are running WinXP Home SP2. The catch is, that the computer
>>> that will be acting as the bridge (the one with two cards, wired and
>>> wireless) connects through a router. So, to summarise, here's my setup:
>>> a two NATs don't make a connection sort of deal?
>>> TIA,
>>> Ari
>> Update:
>> closer. Here's what I did after deleting the bridge:
>> its manufacturer's software
>> receive an IP automatically
>> to the Internet.
>> Cheers,
>> Ari
> the bridge.
> Ari
This also resulted in my wireless adapter completely disappearing, even
after a restart, and so I had to uninstall the drivers, reinstall the
drivers, disconnect the wireless usb adapter, restart the computer,
reconnect the wireless usb adapter, set it to ad-hoc mode again,
recreate the vridge, and check to make sure that compatibility mode was
still enabled (netsh bridge show a).
My problem now is that only one computer can connect at a time to the
bridge in this manner (I tested out a second computer with a wireless
NIC and it ended up with the same IP address as the one I was trying to
get working, and so sort of gummed up the works).
But for tonight, that's enough.
HTH someone else, too,
Ari
