G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi,
I built the following system:
Asus A7V333
AMD Athlon XP 2600+
512 MB Kingston PC2700 DDR CL2.5 RAM
Things have been very stable since I built the system, but just
recently I decided to put in another identical stick of Kingston RAM
to get the machine to 1GB. Since then, the system has been very
unstable. I contacted Kingston and they sent me another stick of the
same model of RAM, but apparently made differently or something, and
this was supposed to fix the problem. Sure enough, I got the new
stick of RAM and the computer is unstable again. I updated the BIOS
to revision 1016, but this didn't solve the problem.
It's weird because it works fine with the single stick of Kingston
RAM, but when I try to upgrade it with a second, it gets really
unstable and all of my games crash. Has anyone else had any issues
with Kingston RAM, or does anyone know a solution to this problem?
Hi,
Asus A7V333
AMD Athlon XP 2600+
