G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus,nz.comp (More info?)
Machine spec:
Asus A7V8X-MX
Athlon XP2600
512MB DDR266
Integrated audio, video
WDC WD800JB-00FMA0 HDD 80 GB
ASUS CRW5232AS CD rewriter
There have been a few instances of it failing to detect the HDD on
startup, or taking a very long time to complete detection. The BIOS
settings are to auto detect the HDD each time the machine starts. This
is a new computer only 3 months old.
On this occasion after "Primary master hard disk fail" was reported I
went into the BIOS settings and attempted to have the drive auto
detected by the setup program, which also failed. However on the next
power up of the machine the HDD was detected and I was able to get the
HDD parameters entered into the BIOS.
On other occasions that I have observed, auto detection has been
extremely slow, and/or boot times have been extremely slow to complete
booting and loading Windows XP.
The power supply voltage monitor reads the following voltages:
Vcore 1.71 V
3.3v 3.34 V
5.0v 4.91 V
12v 11.55 V
CPU temp 32°C
MB temp 25°C
Bios revision: 1003 (current release is 1006). No specific related
issues addressed by any released BIOS updates.
Have looked in the case and can see no problems, all connectors and
jumpers on the HDD appear to be properly seated.
Machine spec:
Asus A7V8X-MX
Athlon XP2600
512MB DDR266
Vcore 1.71 V
3.3v 3.34 V
5.0v 4.91 V
12v 11.55 V
CPU temp 32°C
MB temp 25°C
