Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I moved my hard drive to a new system and now the system just reboots to the screen that says the previous boot was unsucessful. Select bootloging, vga mode, last known good configuration. Whatever I select, it just reposts and returns to that screen. When I watch the logging on the screen, it stops at the mup before it restarts. What have I done wrong? Thanks
Greetings --
Normally, and assuming a retail license (many OEM licenses are not
transferable to a new motherboard), unless the new motherboard is
virtually identical (same chipset, same IDE controllers, same BIOS
version, etc.) to the one on which the WinXP installation
was originally performed, you'll need to perform a repair (a.k.a.
in-place upgrade) installation, at the very least:
As always when undertaking such a significant change, back up any
important data before starting.
This will also require re-activation, unless you have a Volume
Licensed version of WinXP Pro installed. If it's been more than 120
days since you last activated that specific Product Key, you'll most
likely be able to activate via the internet without problem. If it's
been less, you might have to make a 5 minute phone call.
You can have peace. Or you can have freedom. Don't ever count on
having both at once. - RAH
"warren" <anonymous@discussions.microsoft.com> wrote in message
news:85DA456C-79AE-4E6F-A755-8FE6D96D28ED@microsoft.com...
