G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hello,
I got me a new mb and cpu, a K8V and an AMD3500+.
Works great, only one thing is strange. When I enable Coll and quiet
everything is fine, but after a few period of time the CNQ utility from Asus
lock up with a strange message " "," is not a valid option ". The comma in
the message is in " ". Now with that message I do not know where to search.
I enabled the PCi 2.0 feature, the CNQ feature in the bios and set the
correct settings in windows and if I check the tool the switching up and
down works. It shows me values from 1000Mhz up to 2200Mhz and jumps around
as I load applications.
In one word it does what it is supposed to.
BUT then after a period of time ot simply locks up. And from that time on
the clock freezes at the last value. Just a reboot helps.
Strange is that windows works correct, only at 1750 Mhz.
I got the K8V and a zalman 7000a cooler. The only thing is I got a
temperature controlled PSU.
Only thing I could think of is: I had to disable all tempertue measuring in
the bios cause otherwise the rpm of the fans is too low 1350 rpm. Perhaps I
should speed these up and/or put the fanmate up to max performance or put it
completely away and plug the fan directly into the mainboard.
Anyone any ideas?
Hello,
Anyone any ideas?
