Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a machine with a P4P800S, BIOS Rev 1005. The problem I am
having is that when I select the power on from mouse, or even power on
via the keyboard, it does not work!
On another system with a gigabyte motherboard, where the power on by
mouse feature works, I notice that the mouse is powered up - but on
the ASUS P4P800S, the mouse is NOT powered.
Has anyone else experienced this??? Is there a fix? A "beta" bios
perhaps??
Just a thought: does the +5VSB line on your power supply supports at least
1A? I think it's one of the requirement for that feature.
Ray.
"Cloaked" <CloakedRun2001@NOSAPM.yahoo.ca> wrote in message
news:410fa5c9.1280859@news.individual.net...
> perhaps??
> All help greaatly appreciated.
On Tue, 03 Aug 2004 14:51:29 GMT, CloakedRun2001@NOSAPM.yahoo.ca
>perhaps??
Do you have 'Instant Music' enabled in the BIOS? That prevents power
on via mouse or keyboard working.
I double checked this, and it is disabled.
Thanks
On Tue, 03 Aug 2004 18:02:07 +0100, chrish@easynet.co.uk (ChrisH)
>>perhaps??
>ChrisH
On Tue, 3 Aug 2004 11:34:32 -0400, "povmec"
Never heard of that one before. How do you check?? Is the rating
printed on the Power Supply??
>Ray.
>> perhaps??
I guess it's on your power supply. What is the brand and model?
news:410fcc82.143046@news.individual.net...
least
> >Ray.
> >> perhaps??
In article <410fcc82.143046@news.individual.net>,
The rating is usually printed on the label on the side of the PSU.
There are five "power option" headers on your board. They are KBPWR1,
USBPW12, USBPW34, USBPW56, and USBPW78. Each of these is a three pin
header. In one position, the jumper selects operation from +5V. Since
+5V only runs while the computer is running, it is not a good
voltage to use to wake the computer. The other setting is +5VSB.
The +5VSB runs as long as the switch on the back of the computer is
in the ON position, and +5VSB is an excellent choice for powering
a mouse or keyboard that is used to wake the computer. Move the
jumper for the header that powers the "wake" device, and you may have
better luck.
HTH,
Paul
> >Ray.
> >> perhaps??
Thank you Paul, that was it!
I wonder what ASUS was thinking???? What ever happened to "JUMPER
FREE" configuration!!!
I would never have dreamed that a NEW motherboard of this generation
would have had jumpers that needed to be manually set.
Thanks to all who responded.
>better luck.
>HTH,
> Paul
>> >Ray.
>> >> perhaps??
Your bios version is way out of date, 1005 is the bios version that
originally came with the system, I have the same board P4P800 running bios
version 1016.002
Try updating your bios first
> perhaps??
Thanks, but the P4P800 is different from the P4P800S. The currently
"released" bios for the P4P800S is 1005 acording to the ASUS web site.
On Wed, 4 Aug 2004 08:38:14 -0400, "*FTB*~PrimeEvil~"
>version 1016.002
>> perhaps??
