Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have the 3.2E (P4C800) with a Zalman 7000B-Cu
(http://www.zalmanusa.com/usa/product/code_list.asp?cate=03040506)
cooler (with arctic sliver thermal paste) and my temps are at
44C(no-load, just running XP) to 53C(under load). However you need to
consider your case cooling and ambient temps which will change the
results you may get with Zalman.
*FTB*~PrimeEvil~ wrote:
> Heat Problem with the Prescott
> Just went to a Prescott 3.0E Ghz
> Just running windows is 55C / 131F
> In Doom3 temp rose to 78C / 172F, Useing the stock fan that came with the
> processor. (Retail)
> The stock cpu fan from intel isn't cutt'n it, wtf
> So if some one has and suggestions of what type of 3rb party fan would be
> good for this processor let me know here in this thread.
On Wed, 4 Aug 2004 08:29:25 -0400, "*FTB*~PrimeEvil~"
>processor. (Retail)
Prescotts run hot! I've got the same CPU and this warm weather it's 48
idle and 60 full load (running ClimatePrediction.net). I'm using a
Zalman7000Cu with the fan running top speed, and the case is a
CoolerMaster Praetorian also with the fans running 100%.
Without the Zalman I'm sure mine would be at 78 like yours!
"*FTB*~PrimeEvil~" <prmevil37@comcast.net> wrote in message
news:sICdnWAk3_o-S43cRVn-iQ@comcast.com...
> processor. (Retail)
"ChrisH" <chrish@easynet.co.uk> wrote in message
news9v1h09e5dqm668s4epd8uhslc7phusdlj@4ax.com...
> >processor. (Retail)
| processor. (Retail)
On Tue, 28 Sep 2004 18:23:04 +0200, "Driekes"
<biker_driekes@hotmail.com> wrote:
>One importend thing, see the yellow attention sheet in the processor box.
>You should use a "Prescott ready" case. In the side panel of these cases are
>pipes installed so the processor can get cool air from outside. See
>www.intel.com/chassis. I use the Enlight 7254 ande the 4105 without any
>problem. CPU themps don't get higher than 45 degree C, idle or stressed. And
>due to this the noise of the CPU-fan is not to high.
>Cheers,
