G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just built a new pc using the P4P800E MB with the current bios. Not
using raid. Running WinXP Pro. One hard drive on 1st IDE channel,
DVD burner on 2nd IDE channel, and one hard drive on SATA. The OS in
installed on the SATA drive. Sometimes the computer will hang up, and
when I reboot the SATA drive is not recognized as being present.
After powering off, unplugging, and replugging the SATA cable, it then
shows up in the bios and I am able to change boot priority and reboot
as normal. This problem has been reoccurring periodically and I have
not been able to track it down. I have tried both SATA slots and new
SATA cables with no difference. Is it more likely the MB that is
causing the problem, or the HD? Sometimes it will run for days, and
other times just for minutes before this happens.
