G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus,de.comp.hardware.cpu+mainboard.amd (More info?)
I'm glad that I could resolve a couple of problems that all go back to
the same problem. I participated in several discussions along the way,
and now I want to share what I learned with as many of you helpful
people as possible. Most important discussions were:
Re: Welcher Speicher damit ASUS K8V stabil läuft?
de.comp.hardware.cpu+mainboard.amd - 9. Sept. 2004 von Tillerman (8
Beiträge)
ASUS K8V SE deluxe Who uses Cool&Quiet?
de.comp.hardware.cpu+mainboard.amd - 21. Juli 2004 von Tillerman (2
Beiträge)
Re: K8V SE Deluxe: HD-Controller Problem?
alt.comp.periphs.mainboard.asus - 30. Juni 2004 von Tillerman (7
Beiträge)
Conclusion of the problem:
- spontaneous reboots under windowsXP
- disc write failures, loss of partitions
- thus installation failures occurred all along the several windows
installations, causing many "side-effects"
Who's the bad guy?
- I pinned down the problem to the Cool'n'Quiet - function of
processor and mainboard. As soon as C'n'Q was disabled in BIOS and the
AMD processor driver uninstalled, the system worked OK. But far too
hot for summerdays. This was difficult to find out because of the side
effects of the faulty installations. First I thought it was the
HD-controller going mad...
- Since yesterday I know that Cool'n'Quiet actually does work well and
is not bugged. It does cause problems if you have 2 double-sided
memory modules installed in your system. I am running 2 512mB modules
and did not know anything about single oder double sided stuff at all.
The logical layout of 512mB modules appears to be double-sided, even
if you have memory chips only at one side of the module. You CAN get
single-sided modules providing 512mB per module, but they are rare and
expensive. Thus anybody with 2 modules will most likely have the
instability problems when running C'n'Q!
(To check: run the system with C'n'Q and use Prime95 from mersenne.org
to detect "hardware problems". Now remove one of your memory modules
and try again: no problems!)
Solution:
- I will try 2 new modules (now MDT, then Kingston). Should this also
not work I will try to sell the modules and get one 1gB module. That
would be the most expensive solution, but it is said that it will
finally resolve the problem, which is what all this is about, right?
Thanks to everybody!
Tillerman
Keywords: Cool&Quiet, Cool'n'Quiet, cool quiet
My system:
ASUS K8V SE Deluxe
AMD Athlon 64 3200+
Zalman Cooler
2x512mB DDR RAM 400MHz, MDT = "good german brand"
PNY Geforce 5700 LE 128mB
Drives:
160gB Maxtor 7.2k 8mB
160gB Samsung 5.4k 2mB
80gB WD 7.2k 2mB
Ricoh 4x DVD+ Burner
(all connected to the PATA controllers of the southbridge rather than
any of the fancy SATA/Raid controllers)
350W AC adapter
Beiträge)
Beiträge)
Beiträge)
Who's the bad guy?
Solution:
Tillerman
My system:
ASUS K8V SE Deluxe
AMD Athlon 64 3200+
Zalman Cooler
Drives:
80gB WD 7.2k 2mB
350W AC adapter
