Using Wireless Router??
Forum General Networking : General Gateways, Routers and Firewalls - Using Wireless Router??
ok, i have to setup a small network for a friend, she already has a Wireless Router.. now, the router works fine with the Computer that's right next to it. but she has another Computer she just bought that's like across the house downstairs.. and she needs it to be Hardwired to the router, cause teh signal blows..
Is there any settings i have to change so this can work?
or can the router only work as a wireless, or vica/versa.
never worked with a Wireless router before.
so she wants one pc to be on wireless, and the other hooked up with a wire on teh same router.. can this be down? and is there anything i will have to change in settings??
thanks alot guys.
RIG
Asus A7N8X Deluxe
80gb Maxtor
Lian-Li PC-60
Lite-On 52X
AMD XP2800+
LeadTek GeForce 4 Ti4200 w/vivo 128mb 8x
Hitachi CML174
1 GB Corsair XMS PC3200 Cas2
Sponsored Links
yes it can be done. Which model router is it?
<i>It's always the one thing you never suspected.</i>
Reply to jlanka
- 0 +
not sure, it's a LinkSys Wireless router, the Front says 2.4ghz or something.. i assume its a newer model, probley bought from either best buy or circuit city
RIG
Asus A7N8X Deluxe
80gb Maxtor
Lian-Li PC-60
Lite-On 52X
AMD XP2800+
Hitachi CML174
Reply to Rob423
- 0 +
does it have 4 ports on the LAN side? If so, no problem. Just hook up to one of those for the physical connection.
Reply to jlanka
I think that model has 4 rj45 ports on the back so you can run a wire. Personally I have no problem running wire and that's what I'd do if I were you. If you don't want to run a wire, I think they make signal boosters that may help the signal drop.
:tongue: <font color=blue>My job is to polish</font color=blue> <font color=green>turds</font color=green><font color=blue>, I</font color=blue> <font color=red>love</font color=red> <font color=blue>my job.</font color=blue>
Reply to sbolinger2
- 0 +
well it's not mine, a friend (my dads friend actually) needs this work done, and yes it had 4 physical port
RIG
Asus A7N8X Deluxe
80gb Maxtor
Lian-Li PC-60
Lite-On 52X
AMD XP2800+
Hitachi CML174
Reply to Rob423
Tom's Hardware > Forum > General Networking > General Gateways, Routers and Firewalls > Using Wireless Router??
There are 455 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
