Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a P4C800 Dx with an AGP, Radeon All-IN-WONDER 9600 Vcard, WinXP, P4
2.1gig and 512 RAM
After I installed the system everything worked fine. A while back the
picture of my monitor stopped using the full screen, after attempting to fix
the problem with new drivers and checking the hardware, I re-formatted the
PC, a Maxtor 80G which requires a DDO program to be fully recognized by XP,
and installed everything anew.
It was fine untill I started a game, Madden 2005, the screen windowed, not
full screen, while the game was on. On exiting the game, the monitor was
full again.
Well, today even the Windows XP desktop was smaller and everything is back
to where I was.
Any help will be appreciated. Thanks!
BTW, on startup, the screen was windowed up to the Win XP Welcome screen.
The screen used to be full all the time, from the start.
On Wed, 22 Sep 2004 20:57:54 -0400, "Cheo Artesano" <cheoartesano@hotmail.com>
managed to one finger type the following:
>2.1gig and 512 RAM
>full again.
>to where I was.
what do you mean full screen.....what is your resolution set on...if your use to
800x600 and then its set to (example) 1024x768...then it will appear to be
smaller and not be edge to edge on the monitor without making adjustment...My
monitor has a 'on screen control' for such purposes.
"De Oppresso Liber"
From Oppression Liberate
jroc® 7th Special Forces Ft.Bragg N.C 18/Bravo
****only thing easy in life is failure****
*******so get tough*******
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
This does not sound like a motherboard issue at all. It sounds more like a
problem with the settings on your monitor.
Did you try setting the screen width and height correctly while the game is
running? Some / most older monitors require setting up for each resolution
separately.
- Tim
"Cheo Artesano" <cheoartesano@hotmail.com> wrote in message
news:Abp4d.91901$Np2.90682@bignews4.bellsouth.net...
> 2.1gig and 512 RAM
> fix
> XP,
> full again.
> to where I was.
> 2.1gig and 512 RAM
> full again.
> to where I was.
wtf does a display problem have to do with a MB?
>>2.1gig and 512 RAM
>>full again.
>>to where I was.
On a different note, why would you need a DDO? Wouldn't a P4C800 and XP
SP1 recognize an 80G drive? You must be using FAT32 vs NTFS.
> "De Oppresso Liber"
On Thu, 23 Sep 2004 07:21:01 -0400, Randy <wald6036@bellsouth.net>
>>>2.1gig and 512 RAM
>>>full again.
>>>to where I was.
I have a P4C800 DLX with Windows XP and a 80gb D: using Fat32 and I
did not need any additional software to set it up.
And as for the closing screen, have you overridden the refresh rate
safeguards, I have seen it mentioned in various groups that using the
incorrect refresh rate can do permanent damage to the monitor.
The nVidia drivers I have has disabled the refresh rates that it
believes that my monitor cant handle, I can override if I want to risk
instability or damage. And yes I did read that you are using a Radeon
card, but I would thing that they control refresh rates as well.
Cheers
>> "De Oppresso Liber"
eTrust EZ Antivirus Protection
Version 6.2.0.28
Engine Version 11.5.0.0
©2003 Computer Associates International, Inc
Update Version 8602
Update Date Sep 22 2004
On Wed, 22 Sep 2004 20:57:54 -0400, "Cheo Artesano" <cheoartesano@hotmail.com> wrote:
>2.1gig and 512 RAM
>full again.
>to where I was.
What's dynamic driver overlay (DDO) for xp ???
New had to install that. what is it for ?
I am using NTSF and when tried to use the HDD without DDO, it wouldn't
detect it.
May be there is the mistake, I will try to install it without DDO.
thanks
"Randy" <wald6036@bellsouth.net> wrote in message
news:0ky4d.191455$%n4.174997@bignews6.bellsouth.net...
P4
> >>2.1gig and 512 RAM
fix
the
XP,
not
> >>full again.
back
> >>to where I was.
screen.
your use to
be
adjustment...My
> > "De Oppresso Liber"
thanks
"yogi" <yogi@yellowstone.np> wrote in message
news:raf5l0dihscue7qa1acv15e904osjda5ng@4ax.com...
P4
> >>>2.1gig and 512 RAM
to fix
the
XP,
not
was
> >>>full again.
back
> >>>to where I was.
screen.
your use to
be
adjustment...My
> Cheers
> >> "De Oppresso Liber"
> Version 6.2.0.28
> Update Version 8602
news:AaG4d.58630$zT6.42391@bignews5.bellsouth.net...
> detect it.
Nope, something else was wrong. Avoid DDO.
YES, expunge DDO from everywhere.
WinXP,
> P4
> > >>2.1gig and 512 RAM
to
> fix
> the
by
> XP,
> not
was
> > >>full again.
> back
> > >>to where I was.
> screen.
> your use to
to
> be
> adjustment...My
> > > "De Oppresso Liber"
> 2.1gig and 512 RAM
fix
XP,
That's false. Using the Maxtor DDO was a HUGE mistake.
There are 1090 identified and unidentified users. To see the list of identified users, Click here.
