G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Hi!
I've suddenly got a problem I need to solve fast.
I've always had my Plextor IDE burner hooked up to the SATA controller of my
Asus A7N8X-Dlx mobo and never had any problems.
Now I can't burn anymore, Nero keeps saying "Disc id not a CD-R(W)" or "Disc
analyzis failed", when I use Plextors CDVDInfo tool it says "Disc is not a
CD-R(W)" for my burner.
I've tried removing Nero, reinstallingand running borth regged and as demo
as well as different versions (Same no matter what), tried Roxio Easy Media
(Just hangs, soft never loads).
Device manager detects what device I have but says "SCSI CDRom device"
Recent changes are update to Win XP Pro SP2
Think I've updated the SATA drivers
Installed Nvidias IDE drivers with last update
Updated (and downgraded) burner firmware
changed burner program..
Have
Windows XP pro SP2
Plextor 40/12/40a IDE burner
So far no success and I REALy need to burn a few backup discs quite soon as
my HDs are filling up.
Only thing that works without problems is burning Bin/Cue with Alcohol 120%,
but that program also chokes on images created by nero (something about
errors in burning protocol).
Anyone got any ideas what to try to fix this so my burner will be correctly
identified and let me burn again?
TIA
Thomas
Hi!
Have
Windows XP pro SP2
TIA
Thomas
