G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus,alt.comp.hardware (More info?)
Hello,
I have a new ASUS A7N8X-E motherboard which shows fan RPM as ZERO
except for the case that the fan is actually being POWERED from the +12V
terminal of the three-pin fan header. Now this is not a problem for the chassis
fan; but it IS an issue with the Power Supply Fan (draws power internally
from the PS) and the CPU fan which is a high-performance model that exceeds
the load capacity available from the fan header (350mA ~ 740mA).
Both the PS and CPU fans provide a fan speed sense connector for the purpose
of RPM monitoring. The PS has wires for both ground and RPM sense. The CPU
fan has only a wire for the RPM sense. Until I ran across this board, the RPM of
both of these could be read out without difficulty despite the fact that they drew
power from another source.
I flashed the board to the LATEST BIOS and the problem still persists. Anybody
know of a way to get around this problem? What would happen if I were to put some
kind of artificial load on the +12V fan header output? Would the ground line also have
to be connected?
*** THESE THINGS USED TO WORK JUST FINE "AS IS" IN THE PAST!!! ***
TO ASUS:
Is this a design flaw or was it done on purpose? Obviously, I MUST be able to
monitor these CRITICAL fans - otherwise I could fry an expensive PS and CPU should
a fan go down and I'd not get any alarm (because I'd have to disable it in order to run
with this board). Yes, over-temp should catch the CPU but by then it may be too late!!
I don't know what protection the PS has built into it (an Antec True 430-watt).
TO AJUMP.COM:
If this cannot be repaired (meaning this is a design flaw - EVERY board will exhibit
the problem) how do I get my money back on it? I also am worried that the ASUS
A7V880 I just had you guys replace under RMA may have the same issue!! I am going
to test this theory as soon as possible. What happens if I have to RMA BOTH boards
requesting refund of the purchase price? Reply to my e-mail as per the instructions in my
signature (or look up customer #11A048238). Thanks.
You may send e-mail if you wish provided it is NOT SPAM. To decode my valid
E-mail address, you will need to remove the <NOSPAM.> and the <666>. I had
to get complicated as spammers are now doing the obvious removal of the word
"NOSPAM" to compile their lists of e-mails...
- G.L. Cross
Hello,
to be connected?
TO ASUS:
TO AJUMP.COM:
- G.L. Cross
