Tom's Hardware > Forum > Motherboards & Memory > Asus > a7n8x: SATA +IDE Problem.
Forum Motherboards & Memory : Asus - a7n8x: SATA +IDE Problem.
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Okay I have been running my machine with a 80 GB and Zip drive on one IDE
channel. And a CD Burner and DVD drive on the other. No problems. I
recently decided to get a 120 GB Sata drive and DVD Burner to replace the CD
Burner.
So my setup is 1x120 GB sata, 80 IDE and Zip on Primary IDE Channel, and DVD
+ DVD Burner on the Secondary IDE Channel. Problem is that the DVD drives
don't show up now. Anyone have any ideas why this might be?
Sponsored Links
> and DVD + DVD Burner on the Secondary IDE Channel. Problem is that
> the DVD drives don't show up now. Anyone have any ideas why this
> might be?
OK, you've bound to ahve checked this, but still... Are you sure that both
are not set as Master?
Best Wishes
Thomas
Reply to Anonymous
Shortly after posting I decided to take the SATA drive out and see what
happens. Upon reboot it then saw only the burner. Taking the burner out, I
had indeed left it as "master". It's always the small things that get you.
Reply to Anonymous
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
