Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Strange keyboard problem (USB-to-PS/2 Adapter)
Forum Windows XP : Windows XP General Discussion - Strange keyboard problem (USB-to-PS/2 Adapter)
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
Hello,
I have an USB-to-PS/2 adapter to connect my PS/2 mouse (Logitech) and my
PS/2 keyboard (Cherry, german keyboard layout) to my laptop (Dell
Latitude D800).
The mouse and the keyboard generally works. But if I press the del- or
pos1-key a screenshot is copied to the clipboard (like if I press the
print key). Especially if I do copy and paste operations using the
keyboard (Ctrl + C, Ctrl + V) it is a bothering problem that the
screenshot is pasted instead of the copied text, if I pressed the del
key before.
I did not need to install a special driver for the USB-to-PS/2 adapter.
There was no special driver included. The WinXP HID keyboard driver (Win
XP Professional, SP1) was automatically installed (kbdclass.sys,
kbdhid.sys) after connecting the USB adapter. I also deleted and
reinstalled the driver. This did not help.
Any ideas how to solve the problem?
Philipp
Sponsored Links
get an english keyboard, the german keyboard layout and function/special keys layout are different than an english keyboard's.
the german keyboard's del key is the same ansi # as the print screen key of an english based keyboard. hence you think your hitting del but instead it's print screen as far as the os thinks
"Philipp Pfeiffer" wrote:
> Hello,
> Latitude D800).
> key before.
> Philipp
Reply to Anonymous
Philipp Pfeiffer wrote:
> Hello,
> Latitude D800).
> key before.
> Philipp
Do what I did (for the same laptop). I use the two USB ports in the back
for the mouse and keyboard (both wireless Logitech). Then I purchased a
USB 2.0 PCMCIA card and use that for any USB connections. Right now, I
use it to connect a USB drive and a wireless NIC.
courtney sends....
One other thing you can do. Belkin has a keyboard/mouse device. It has
two PS/2 connections on one side, and one on the other. This will allow
you to connect both, the keyboard and mouse, to the single PS/2 on the
laptop.
Reply to Anonymous
Hi Corutney,
> USB 2.0 PCMCIA card and use that for any USB connections. [...]
My problem is not how to connect the keyboard and mouse to the laptop
but how to get my keyboard working properly.
I have no ps/2 ports at the laptop, so I need the usb-to-ps/2 adapter to
connect my ps/2 keyboard. I do not need additional usb ports.
Best regards,
Philipp
Reply to Anonymous
your not a lone! I've had that same problem when I used an older keyboard which had a ps2 plug with a usb converter on my laptop that didnt have a ps2 port. I liked the older dell keyboard better, the keys are higher and had better 'bounce'. The new one has very very thin keys and they get stuck quite a bit.
I thought I was going crazy! It seemed like it was continually copying the full desktop (via alt-print sreen). I could open any program that accepts graphical input and paste it. It appeared to update every few seconds, 5 or 10. This was bad enough, but more importantly, when I program I use the copy and paste functionality tremendously - Try going without it for an hour or so.
My resolution is just to use the cheapy new keyboard.
Message edited by tomtoms_advice on 07-16-2009 at 08:53:17 PM
Reply to tomtoms_advice
There are 1319 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 torbee won the Freshman badge
  • 01:00 dba won the Uniformed badge
  • 01:00 LoveMyslf won the Uniformed badge
  • 01:00 survdirt won the Uniformed badge
  • 01:00 vgigolo won the Uniformed badge
  • 01:00 alex3003 won the Uniformed badge
  • 01:00 dindarloo won the Uniformed badge
  • 01:00 Akash Nain won the Uniformed badge
  • 01:00 greeneman510 won the Uniformed badge
  • 16:28 bilbat won the Motherboards badge
