G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I have a 500W power supply that has run stably with a 2.8GHz Pentium 4
CPU on a ASUS P4C800 Deluxe mobo over the past 6 months. The other day
I was given a 3GHz Pentium 4 CPU. I swapped out the old CPU and fan
and installed the brand new boxed CPU and fan. However ever since I
have made the swap over, the fan in the power supply has been working
about twice as hard as it did when the 2.8GHz cpu was installed. It is
now twice as loud as it was before and the extra noise is quite
annoying.
Has anyone else ever experienced this problem? What could possibly
make the fan of a power supply work harder like that. Surely the extra
power to run a measly 0.2GHz of extra CPU clock speed in a CPU is not
enough to cause this effect in a 500W power supply?
Another annoying new feature since the CPU swapover is random power
supply shutdowns. Sometimes when I am making the system work hard,
the system suddenly does down. It is like someone has come along and
pulled the plug out of the wall socket. I am suspicious that perhaps
the new heatsink and fan assembly is not making proper contact with
the top of the CPU resulting in inefficient heat transfer, and an
overheating CPU.
I checked with the ASUS website and noticed some circuitry that
appears in several of their boards called ASUS C.O.P (CPU Overheating
Protection). However this technology is not listed as being part of
the ASUS P4C800 Deluxe. Can anyone confirm if it is actually there or
not?
I shall take the cover off the case tomorrow when I am not so tired
and make sure I haven't done something bonehead like connecting the
CPU fan power supply to the case fan supply by mistake.
I was always under the impression that power supply fans were not
variable speed.
annoying.
overheating CPU.
not?
variable speed.
