G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Recently I purchased a P4C800 Deluxe motherboard along with a 3.2 Ghz
Northwood P4 to go along with it. I received the parts, installed
everything properly (so I thought), and turned on the PC. As soon as
pressed the power button, something on the motherboard burned up.
After turning it off and looking at it, it appears to be whatever is
(was) to the right of the IEEE 1394 internal controller at the bottom
of the board. The green light still comes on if I turn the MB on, but
I get an (auditory) error message: "Warning CPU Test Failed." I'm not
sure if this was related to the "burn out" or not. If my assumption
is correct and it has related to the firewire controller, it seems
conceivable to me the MB would still operate. The only error I could
figure out that I made was failing to connect the secondary 12v power
supply at first, but it doesn't seem plausible that that would have
caused this problem. So my questions are:
What do you think could have caused this to happen?
Do you think the warning message I received regarding the CPU was
related, or a separate issue entirely?
If the problem is isolated to the IEEE 1394 controller, is it safe to
use the motherboard provided I don't need this feature?
Thanks in advance. I've put together my fair share of computers but
I'm by no means an electrical or computer engineer. I've never had a
problem like this before, and I'm really unsure of how to proceed.
Regards,
Dave Thoma
Regards,
Dave Thoma
