Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I have just purchased the above and also upgraded my PC
to USB 2.0 by adding a Belkin Hi Speed USB 2.0 pci card.
The card seems to be working OK.
The drive does not appear to be working properly. If I
boot up the PC and then plug in device it is shown as a
drive and also as a mass storage device in Device
Manager. If the PC is then booted up with the USB cable
still plugged in the drive is not recognised and the
system becomes unstable. On a couple of occasions this
has resulted in the Blue screen with a stop message 0X
000000D1 which I understand is a driver problem!
I have also tried the drive in a different PC with 1.1
USB ports, it recognised it as a USB 2.0 device in "found
new hardware" and then went on to say that the device did
not install fully and may not work correctly. It did show
as a drive on the machine!
Anybody got any ideas before I return this drive as
faulty?
Thanks
faulty?
Thanks
