G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
well i just decided to upgrade and bought an asus a7n8x-e, athlon
2800+, nvidia 6800 gt, (2x) 512mb crucial ram, etc. The only major
problem i am having is that i cannot get my computer to use my modem.
It recognizes it fine and will install it back automatically if i
delete it. i don't think it's the modem. every time i attempt to add
a dial-up connection i get an error 711 which states something to the
effect that some setting on my computer is restricting it from adding
a connection. I'm running xp pro and need help badly!!!!!
