Archived from groups: microsoft.public.windows.networking.wireless (More info?)
Hi i am having some trouble networking my laptop to my main
system. I have installed the software to my laptop and
they find each other. But when i try to connect to the
internet on the laptop through the main one it does not
connect. Also i can not see the shared files from either
system. Can any one help
Sponsored Links
"Dean" <bonehead69@tiscali.co.uk> wrote in message
news:04d301c4f278$b8fea530$3501280a@phx.gbl...
How are you connecting to the network? Through a router, switch, hub, cable
wireless, wireless access point, ad hoc set up?
Reply to Tony
>-----Original Message-----
switch, hub, cable
Hi i have a wireless laptop adapter, i think i am set up on
ad hoc. i connect to the internet by usb broadband modem.
Reply to Anonymous
- 0 +
Hi
Making the Wireless Home Network Connection in Windows XP Without a
outer -
http://www.microsoft.com/windowsxp [...] 02april08.
mspx?pf=trueHi
Howvevr I might add that you would have a more flexible stable Network if
the whole thing is around a Wireless cable/DSL Router. 802.11b Wireless
Router can be found on sales for less than $20.
Your problem is the USB Modem (USB modem do not work with regular cable/DSL
Routers).
If you plan in the near future to enlarge your network you would need to
invest in an External Ethernet Modem, and if your Broadband is DSL I would
do it even for single computer.
DSL-PPPOE http://www.ezlan.net/PPPOE.html
Jack (MVP-Networking).
<anonymous@discussions.microsoft.com> wrote in message
news:133001c4f296$231dfac0$a301280a@phx.gbl...
> switch, hub, cable
Reply to Jack
- 0 +
hi thanks for the advice could i use a ADSL MODEM WITH
WIRELESS G ROUTER will this get round the problem.
Dean
>Hi
Without a
>outer -
>http://www.microsoft.com/windowsxp/using/networking/expert/bowman_02april08.
>mspx?pf=trueHi
stable Network if
802.11b Wireless
regular cable/DSL
>Routers).
you would need to
my main
>> switch, hub, cable
Reply to Dean
if you are using a USB modem you will have to use a proxy program loaded on
the computer connected to the mmodem in order to share your internet
connection. I once had the same setup and used wingate as my proxy and it
worked fine.
I suggest getting a modem with an ethernet connection though, it would make
your life alot easier.
"Jack" <JackMDS@verizon.net> wrote in message
news:Ohyl5J38EHA.3596@TK2MSFTNGP12.phx.gbl...
> Hi
> outer -
> mspx?pf=trueHi
> cable/DSL
> Routers).
>> switch, hub, cable
Reply to Anonymous
Tom's Hardware > Forum > Wireless Networking > Wireless General Discussions > wireless networking
There are 1266 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
