For some strange reason the TCP/IP protocol will not work with my NIC unless I uninstall my modem. In the network properties in the control panel it shows that TCP/IP is installed with the NIC and modem, but, only the modem will work with TCP/IP. Any ideas on what the prob is? BTW IPX works fine.
What was used to program a programming program?
