power low on +3.3 power level
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
i have just upgraded to an asus mobo that shows voltage levels, they are all fine except the 3.3 level, im currently knocking out about 2.9 volts. i have not had any hangs or reboots, so the power pack seems to be holding up ok. its 230 volts, do i need to upgrade or will it be ok to leave alone?
G
Guest
Guest
Depending on the motherboard voltage regulation, voltages
will vary depending on the CPU and chipset.
Check the ASUS mobo manual to see what the voltage should be
for your configuration.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"------------daz--------------"
<daz@discussions.microsoft.com> wrote in message
news:6D567720-51C0-4E40-A99E-4EBF17668303@microsoft.com...
alone?
